ᐅ Kallax unit disassembled and reassembled multiple times after moving – any damage?
Created on: 5 Jan 2024 08:14
Elpubi
I have a specific question regarding the Kallax shelving unit from Ikea. After moving, I have now taken apart and reassembled my Kallax unit three times, each time to make it easier to handle during transport. I have noticed that some of the connectors and corner joints seem a bit loose or show minor signs of wear after repeated disassembly and assembly.
My question is: Can repeated disassembly and reassembly of the Kallax system cause damage, for example to the dowels or joints due to stress? Or is the furniture generally designed to withstand this without any issues?
How about its stability in particular when it is frequently transported and rebuilt? Are there any known weak points to watch out for?
I would really appreciate any experiences and opinions, especially from those who have moved used Kallax units multiple times. Thanks in advance!
pikin
5 Jan 2024 10:16
From a technical perspective, the joints, especially the wooden dowels, are not designed to be used as multiple connection points. Each time the piece is disassembled, slight material deformation occurs in the drilled holes, which reduces the precision of the fit.
Even though the furniture itself is made from sturdy material, the accuracy of the connections decreases with repeated disassembly, potentially leading to reduced stability.
Based on my experience and the design, the Kallax is intended as a permanently assembled piece of furniture, not as a mobile system that is frequently taken apart and reassembled.
If you move frequently and disassemble and reassemble the shelf multiple times, I would recommend using additional fasteners or switching entirely to robust metal brackets to compensate for stability loss caused by worn dowels.
SETHBLA
5 Jan 2024 10:45
I can confirm: anchors are a weak point. When rebuilding, always use a bit of glue for stability and replace anchors with new ones if the fit is very loose. That way, it will hold again.
flo-Theres
5 Jan 2024 11:23
If it helps: When assembling and disassembling multiple times, small drill holes for screws can be made on the inner edges at critical points without significantly altering the appearance of the furniture. This way, the piece can be kept stable without relying solely on the dowel mechanism.
By the way, it is important to pay attention to the maximum load capacity of the shelves. If stability decreases, there is a risk that the shelves may eventually bend or break.
GiRoyce
5 Jan 2024 12:02
Elpubi schrieb:
How do you best replace the dowels in the Kallax?
I can only agree that completely disassembling it is usually unavoidable.
However, if you are careful and avoid using force, the parts can be handled quite well. Also, make sure to always assemble the shelf flat on an even surface so the dowels fit correctly.
So yes, repeatedly assembling and disassembling is doable if you take your time and work carefully.
GALENKU
5 Jan 2024 12:35
Anchors become looser with repeated use. If the shelf starts to wobble, consider adding extra reinforcements or installing new anchors.
Elpubi
5 Jan 2024 18:13
Thanks for the good assessment so far.
I’m also interested in whether there are any differences between the Kallax shelves, for example between the different sizes (2x2, 4x4, etc.) or between older and newer versions in terms of the connection quality?
I could imagine that in larger models, the stress on the connections is greater, which might lead to faster wear. Does anyone have relevant experience or observations?
I’m also curious about the surface (painted or foil) in terms of whether repeated assembly causes wear or damage to the edges.
