ᐅ Is it worth buying a custom-made Kallax?
Created on: 11 Aug 2020 09:23
chennon
chennon
11 Aug 2020 09:23
Hello everyone, I am considering getting a custom-sized Kallax unit because the standard size does not fit my space well. My specific question is: Is it really worth buying a customized Kallax version? I especially want to know if the additional cost is justified in relation to the benefits—such as storage capacity, appearance, quality, and flexibility. Has anyone had practical experience with this? I would also appreciate information on delivery times and the durability of the custom units compared to the standard models. Thanks in advance for your insights!
fepau
11 Aug 2020 10:37
It’s great that you’re considering a custom-sized Kallax! 🙂 Speaking from personal experience, it’s definitely worth it, especially if you have specific room dimensions that a standard shelving unit can’t fully utilize. Custom adjustments provide real added value—you can design the shelf exactly the way you need it! Of course, it costs more, but the investment pays off, particularly if you care about a great look and want to keep things organized in the long run. So, definitely give it a try!
roryvin
11 Aug 2020 11:01
fepau schrieb:
The custom settings provide real added value.
That is basically true, but the price increase should be considered realistically. Compared to a standard Kallax, the surcharge is often between 30 and 50%, depending greatly on the supplier. It is important that you measure the space precisely and are clear about which features you really need. In addition, the delivery time is usually extended by several weeks. So, unless a special size is absolutely necessary, the standard model is often the more economical option.
SUDAN
11 Aug 2020 12:15
To help you make a better decision, here are a few pointers:
1. Measurement: Precise measuring is crucial for custom-made items to avoid problems and incorrect purchases later on.
2. Material Quality: Custom-made products are usually based on the same material as standard Kallax units, so the quality is comparable.
3. Flexibility: Upgrading or modifying custom-made pieces is often more limited because you receive elements cut to exact dimensions.
Common mistakes: If you don’t accurately determine the ceiling height, you’ll likely end up frustrated with unnecessary gaps or ill-fitting shelf compartments. So avoid making rushed decisions!
Ellis
11 Aug 2020 13:02
Kallax custom sizes are great if you need specific dimensions. If not, the standard model is more affordable and available more quickly.
Surela
12 Aug 2020 08:47
I would like to go into more detail here because choosing a custom-sized Kallax requires more careful consideration than one might initially think.
First, regarding the technical aspects: The Kallax panels are cut precisely for custom sizes, and connection elements may also be adjusted—however, this can affect stability. For example, if you plan a very tall or wide compartment, reinforcements are necessary, which IKEA usually includes in their standard models.
Furthermore, I advise you to pay attention to the surface finish. Custom sizes sometimes have a thinner melamine coating to conceal cut edges, which can lead to wear over time.
As for the process: Some manufacturers require exact measurements with little room for tolerance. Deviations of just a few millimeters can make assembly difficult. Perhaps you already have a sketch or precise measurements to share? This would allow for more tailored advice based on your situation.
