ᐅ Kallax warped after installation in a recessed space – how to straighten it?
Created on: 28 Feb 2020 17:13
glate
Hello everyone, I have installed a Kallax shelving unit from IKEA into a recess that fits almost perfectly. Unfortunately, I noticed that the shelf has warped slightly due to the physical pressure from the side walls. The top and bottom panels are no longer completely flat, and the side panels are slightly bowed. The shelf is made of particle board, and I suspect that the clamping caused a slight distortion. My question is: Is there a way to straighten this deformation afterwards? I would rather not remove the shelf completely, as it fits very well in the recess, but it obviously doesn’t look ideal and also affects stability, especially when I place heavy loads on the shelves. Are there tools or tricks to bring the wood back into a straight form without damaging it? Maybe using clamps or something similar? I look forward to your experiences and advice!
glate schrieb:
The shelf is made of particleboard; I suspect that the clamping caused slight warping.This is an important observation. Particleboard is indeed sensitive to pressure and even slight variations in humidity. In addition to the methods already recommended, I would suggest fully unloading the shelf and, if possible, creating some space between the shelf and the niche wall by placing small wedges or felt pads underneath. This allows the shelf to relax freely again.
Also, if the warping makes the shelf unstable, you can attach cross braces on the back or inside to add extra stability and prevent further warping.
One more thing: when putting the shelf back into the niche, make sure it’s not fitted too tightly—a little clearance helps avoid future deformations. Many forget that especially shelves like Kallax can easily be compressed due to varying material thicknesses and uneven walls.
