ᐅ Assembly Order for BILLY Shelves – Is There an Easier Method?
Created on: 21 Dec 2023 18:13
Patena
I am planning to assemble my Billy shelf, but I am currently facing the challenge of finding the optimal order of assembly—especially regarding the combination of the side panels, shelves, and back panels.
The enclosed instructions do describe the sequence, but I find it a bit unclear and somewhat awkward, particularly if you want to assemble the shelf without using clamps. Is there perhaps a simpler method or a proven workflow that makes the assembly more efficient and stable?
I look forward to your tips and experiences, especially on how you handle the order of the individual components and whether a different approach has worked better.
Patena
22 Dec 2023 17:39
Thanks to everyone for the helpful contributions! Especially the advice about placing it on its back and the correct sequence really helped me.
I will try it this way now:
- First, prepare the side panels
- Partially screw in screws/dowels
- Insert the shelves
- Then attach the back panel while it is on its back
- Only after that, stand the shelving unit upright and tighten all screws
If I encounter any problems, I will get back to you.
neoren
22 Dec 2023 18:01
Sounds good! If you have a wall fixing, install it after setting up. It will save a lot of trouble later if the shelf tips over.
Cecilera66
22 Dec 2023 20:15
Just a quick note: Before standing the shelf up, check that it is level. A small gap or shims can help if the floor is uneven.
Elijah42
23 Dec 2023 09:50
Just as an additional note: Always align the back panel precisely at the corners. Otherwise, screwing it in will be difficult and the shelf may become warped.
Jeanbar
23 Dec 2023 10:44
Very good addition, @Elijah42. Even if the back panel is flexible – if it is installed unevenly, it will cause uneven stresses.
Patena, if you place special importance on accuracy: A square can be very helpful when aligning the back panel.
Patena
24 Dec 2023 11:27
Update from me: I assembled it yesterday following your tips. Mounted the back panel while lying on my back, prepared the side panels and shelves beforehand. It was actually easier and more stable than I expected.
Thank you very much for the detailed explanations and motivation! 🙂
