ᐅ Kallax warped after installation in a recessed space – how to straighten it?
Created on: 28 Feb 2020 17:13
glateHello everyone, I have installed a Kallax shelving unit from IKEA into a recess that fits almost perfectly. Unfortunately, I noticed that the shelf has warped slightly due to the physical pressure from the side walls. The top and bottom panels are no longer completely flat, and the side panels are slightly bowed. The shelf is made of particle board, and I suspect that the clamping caused a slight distortion. My question is: Is there a way to straighten this deformation afterwards? I would rather not remove the shelf completely, as it fits very well in the recess, but it obviously doesn’t look ideal and also affects stability, especially when I place heavy loads on the shelves. Are there tools or tricks to bring the wood back into a straight form without damaging it? Maybe using clamps or something similar? I look forward to your experiences and advice!
Hello glate,
first of all, thank you for the detailed description of your problem! That really helps with understanding.
Particle boards tend to deform under clamping and pressure because they can warp slightly depending on moisture and the pressure point. To straighten the shelf again, you can try the following:
1. Slightly loosen the brackets or screws if the shelf is fixed, so the wood can relax.
2. Use clamps to press the shelf against a as straight as possible stop. For this, you can use a sturdy, straight batten or board as a counterpiece to distribute the pressure evenly.
3. If possible, remove the back panel completely and then straighten the shelf under even pressure. After a few days, the wood can settle into shape.
4. Optionally, insert wooden wedges or spacers between the shelf edge and the niche to reduce the pressure.
Please work carefully, as particle boards are not as strong as solid wood, and too much force can damage the surface or cause cracking.
I hope these tips help you!
RON57 schrieb:
Chipboard unfortunately tends to warp under clamping and pressureExactly, that’s an important point. I would add that straightening can also be aided by slightly dampening the shelf at a moderately increased humidity (for example, in the bathroom or after a steam shower day) before securing it with clamps. The wood will then swell slightly and can be better positioned.
However, be careful: too much moisture will quickly damage chipboard. So only dampen lightly and briefly, do not soak!
Alternatively, you can use weights evenly distributed over the curved area while the shelf rests horizontally. But this process takes a few days to weeks.
It’s also practical to relieve the shelf compartments themselves, meaning no heavy objects should be placed on them until the shelf is flat again.
Hey glate,
something like that happened to me once as well. I gently warmed the shelf with a hairdryer set to medium heat and then carefully pressed it against a smooth wall using several clamps. With some patience, it straightened out again. Make sure to keep checking regularly to ensure nothing cracks or splinters.
After a few hours, remove everything and check again. Sometimes it takes several attempts.
Small aids like pieces of felt between the clamp and the shelf surface help protect against pressure marks. 🙂
RonJarrett29 Feb 2020 10:02As a supplement: Chipboard, like the one used in Kallax, consists of compressed wood fibers that are relatively sensitive to moisture and mechanical pressure.
To straighten the boards, a process is recommended that relieves internal stresses without damaging the panels:
- Loosen all fastenings that cause tension or compression.
- Apply gentle, even counterpressure using clamps, preferably with protective pads to avoid pressure marks.
- Avoid experimenting with temperature or humidity unless experienced, as the material can swell and be damaged.
- If the deformation is too severe, replacement of the warped parts is often the only solution.
If stability is a concern, you can also add small wooden battens on the backside to reduce warping.
It is always important to perform the process slowly to prevent damage.
