ᐅ KALLAX and Moisture in the Basement – Any Tips?
Created on: 25 Dec 2016 08:13
Arnfried
Hello everyone, I have a specific topic where I need your experience and advice. I am planning to set up a KALLAX shelf unit from IKEA in the basement, but I’m concerned about possible moisture. Unfortunately, the basement isn’t completely dry, especially during the colder months when the air feels quite damp, which can be problematic for furniture made of wood-based materials. Do you have any experience with how to best protect KALLAX boxes or shelving units in a damp basement? Are there special surface treatments, suitable placement options, or dehumidifiers you would recommend? What measures are most effective at preventing mold or warping? I’m looking forward to detailed answers that also briefly explain the background, so I can better assess the risks and carry out my project accordingly.
putan
26 Dec 2016 09:14
Arnfried schrieb:
I understand that the most important factor is the air humidity, not just moisture from the masonry?
Exactly! You can have dry walls, but if the air humidity is high, moisture condenses in cool corners – and the furniture suffers.
Therefore, my advice: place furniture with enough distance from the walls and use indoor air control (ventilation or dehumidifier). The KALLAX prefers a rather dry environment; unfortunately, wax alone often doesn’t help.
bauku
26 Dec 2016 09:59
Hey Arnfried, just a super quick tip: I attached some inexpensive foam pads, about 5mm (0.2 inches) thick, under my KALLAX. They provide excellent protection against cold floors and moisture. Costs almost nothing and doesn’t look obtrusive. Definitely worth trying! 😊
DIGOREN
26 Dec 2016 10:17
Foam pads are a smart choice. Alternatively, felt gliders can be used under the feet if the floor is level.
Arnfried
26 Dec 2016 11:03
Thanks for the tips on the documents.
What do you think about adding additional protective foil on the bottom of the shelf compartments? I believe this could help keep moisture, which might generally be present in the basement, at bay even better. Or is this unnecessary? Does anyone have experience with using foil in combination with KALLAX in the basement?
letar
26 Dec 2016 11:47
Arnfried schrieb:
What do you think about adding extra protective film to the bottom of the shelf compartments?
This is generally not a mistake, especially if you plan to store items in the shelves that must not come into contact with moisture. A layer of PE film or thin plastic sheet can prevent moisture, but air still needs to circulate; otherwise, condensation may build up underneath. Therefore, you should ensure the film is placed only in spots or that the shelves are not sealed airtight.
putan
26 Dec 2016 12:29
Foil can help, but as letar says, air must be able to circulate – otherwise it will get damp and musty underneath. A kind of breathable protective layer would be ideal, but that gets more complicated. 🙂
If it’s just about a bit of protection, plastic boxes in the compartments are enough. That way, you have a physical barrier.
