ᐅ Using Kallax as a Kitchen Cabinet – Potential Issues?
Created on: 3 Jun 2020 18:22
MANLEN
MANLEN
3 Jun 2020 18:22
I am considering using an IKEA Kallax shelving unit as a kitchen cabinet to create additional storage space. I am aware that Kallax is originally designed for living rooms and offices, but since the dimensions are quite practical, I would like to use it in my kitchen. My question is: What potential issues might arise when using a Kallax unit as a kitchen cabinet? I am especially concerned about moisture, stability, cleaning options, and of course the load capacity when storing pots, pans, or dishes. I would appreciate any experiences or tips, particularly regarding durability and maintenance.
Best regards!
Mekau
3 Jun 2020 18:34
In short: Kallax is not water-resistant. Moisture can cause the panels to swell. Additionally, the shelves are not designed for very heavy loads.
lise56
3 Jun 2020 19:05
Interesting approach using the Kallax as a kitchen cabinet. However, I would be cautious regarding moisture. The panels are coated with melamine, which is somewhat water-resistant but does not guarantee long-term durability in kitchen environments.
Additionally, I wonder how the frame will hold up in terms of stability over time with repeated loads, for example, from heavy cookware.
Do you plan to install the shelving unit or use it freestanding? In my view, that makes a significant difference.
MANLEN
3 Jun 2020 19:59
lise56 schrieb:
Are you planning to install the shelf or use it freestanding? I think that makes a big difference.
Good point! I initially thought of using it freestanding, but secured to the wall for better stability. I haven’t looked much into installing it within a fixed kitchen frame since my space is limited and I want to keep it flexible.
Regarding moisture: Of course, melamine is not solid wood, but it’s better than unprotected particleboard. Still, I’m concerned whether steam from the stove underneath might settle permanently and cause long-term damage to the material.
As for weight: I would mainly place pots and pans on it, not heavy ovens or similar items. Would the Kallax hold that load without issues, or is the quality of the shelves a possible concern?
Thanks for your feedback!
chen67
3 Jun 2020 20:22
Hi MANLEN 🙂
Using a Kallax as kitchen furniture sounds interesting. I once had one as a side shelf in front of a window, and it was very practical!
Just regarding moisture: Kitchens can get steamy, which isn’t ideal for the material. But as long as you don’t place the shelf directly in the steam zone of the stove, it should be fine.
As for the load: Kallax shelves can hold quite a bit, but they are just particleboard. I wouldn’t put anything too heavy on it – two full pans and pots are fine, but avoid stacking too much.
Maybe put a nice cloth underneath to provide extra moisture protection. 🙂
FAZAR
3 Jun 2020 21:45
I would like to go into some technical details here, as using a Kallax shelf unit as a kitchen cabinet does present certain challenges.
First, regarding moisture: The panels used for the Kallax carcass are particle boards with a melamine coating. These protect against short-term contact with moisture, but they are not waterproof. In a kitchen, exposure to steam, splashes, or cleaning agents can increase moisture levels, which over time could cause the panels to swell.
Second, concerning stability: The shelves are fixed to the side panels with dowels, which can loosen under heavy load. The maximum load capacity per compartment is about 13–15 kg (29–33 lbs), which is usually sufficient for standard dishes, but caution is advised with heavy pots or pans.
Third, the openings are square, which may make it impractical to arrange wider kitchen utensils. A practical idea is to use boxes or baskets to utilize the space more efficiently and maintain a tidy appearance.
I would recommend securing the unit to the wall with appropriate fastenings to prevent tipping, and possibly adding waterproof film or silicone seals in particularly vulnerable areas.
Where exactly is the shelf planned to be placed? Next to the stove, sink, or rather in a drier corner?
