I recently moved into a new apartment and noticed a rather unpleasant odor coming from my Ikea KALLAX shelf. It’s a new shelf that I assembled right after delivery. The smell is quite strong and reminds me of a mix between damp wood and chemical emissions that just won’t go away.
I suspect it might be coming from the surface or maybe from the treatment of the particleboard, but I’m not sure. Can the shelf itself emit these odors, or is the problem more likely due to high humidity or poor ventilation?
I mainly use the shelf in the living room, where I often open the windows, but the smell is still there. Has anyone had similar experiences? What methods help to effectively neutralize this kind of odor?
Of course, I don’t want to live with a musty or chemical air quality permanently. Thanks in advance for your tips and advice!
warrenka5710 Jun 2024 09:12David53 schrieb:
The smell is quite strong, reminiscent of a mix between damp wood and chemical fumesThat sounds really unpleasant. I once had something similar with a Billy bookshelf. It feels almost suffocating when something like that is in the room.
Sometimes it’s due to the finishes or adhesives in the wood particleboard material. New furniture often needs a few weeks to off-gas. Maybe just ventilate more frequently, even if it’s uncomfortable—that can take time.
But you’re right: you shouldn’t just ignore the smell because it’s not healthy in the long run. Have you tried treating the shelf with vinegar water or activated charcoal? That can sometimes help cleanse the air.
Please keep us updated on how it develops!
Hello David53,
to better address the issue, here is an overview of why such odors occur and what you can do to specifically counteract them:
1. Cause: Furniture made from particleboard or MDF often contains adhesives with formaldehyde or other solvents that off-gas and produce this chemical smell.
2. Ventilation: Fresh air helps reduce the concentration of these substances. Ideally, you should place the shelving unit in a well-ventilated area.
3. Surface treatment: If the shelving is painted or covered with a laminate or foil, odors can become stronger when humidity is too high.
4. Steps to take:
- Make sure to ventilate the room almost constantly, even if it’s difficult during summer.
- A dehumidifier can lower humidity, which reduces off-gassing.
- Place activated charcoal or special odor absorbers inside the shelves.
5. Alternative: If you cannot control the smell, one option is to let the shelving off-gas outdoors or in a garage for a few days.
I hope this summary helps you decide and resolve the problem.
4. Steps to take:
Hello David53,
I can understand that such an odor can be disturbing. First, it is important to understand the material. KALLAX boxes are usually made of particleboard, which can indeed emit chemical odors, especially when newly unpacked.
If the smell is very strong and persistent, you should check for possible moisture in the room, as this can intensify the odor substances. A hygrometer for measuring humidity can help with this.
Additionally, you can leave the cabinet doors or shelves open and place bowls with vinegar water or baking soda nearby. Both substances help absorb odors.
These processes require patience; the odors will not disappear immediately. It is important not to place the shelving unit directly against damp walls and to ensure regular air circulation.
If it becomes uncomfortable in terms of health (headaches, breathing difficulties), you should temporarily remove the shelving unit.
