ᐅ Replacing Kallax Back Panel with a Different Material – Is It Feasible?
Created on: 15 Aug 2019 17:44
Montez2
Montez2
15 Aug 2019 17:44
I am currently considering whether it is possible to replace the back panel of an Ikea Kallax shelf with a different material. The standard particleboard backing serves its purpose but is relatively thin and not very convincing in terms of stability, especially if you want to modify or enhance the shelf for multifunctional use.
Has anyone had experience using, for example, an MDF board or plywood as a back panel instead, without losing stability or precise fitting?
How about the attachment method? Does the back panel simply slide in, or is it nailed, screwed, or glued?
I would prefer not to damage the original parts but still want a sturdy result that also looks better. Are there any tips regarding the thickness of the material or processing (e.g., sanding edges, pre-drilling, sealing)?
I would appreciate any helpful advice, experiences, or warnings about potential difficulties!
Fredlo
15 Aug 2019 18:03
Montez2 schrieb:
Has anyone here had experience with using, for example, an MDF board or plywood as a back panel instead, without losing stability or accuracy of fit?
That’s great that you’re taking this on! 🙂 I did exactly that – I used a thin plywood sheet, about 6 mm (1/4 inch) thick. I simply cut it to size, a bit smaller than the original back panel, and instead of nailing it, I fixed it from the inside with small brackets.
The fit doesn’t have to be perfect; a little wiggle room is actually helpful for easy installation. The stability definitely improved for me, especially since the back panel hardly wobbles now. I sanded the edges slightly and painted them with acrylic paint, so it even looks more refined.
I’d only use glue if you want the back panel to be permanently fixed – I prefer screws or brackets so it can be replaced if needed.
In summary: yes, it works perfectly, and you can customize it to your liking! So get the saw ready, it’ll turn out great! 😉
Jaime
16 Aug 2019 09:27
To add a more technical perspective: MDF or plywood are generally suitable materials, provided they aren’t chosen too thick. A thickness of 4 to 6 mm (0.16 to 0.24 inches) is usually sufficient due to the Kallax construction method; otherwise, fitting issues may arise because the groove on the side of the shelves only accommodates a limited material thickness.
It is important to secure the material appropriately according to the load. Screws or small angle brackets on the inside are recommended, as the rear groove supports in Kallax are not designed for thicker materials.
Additionally, the material should be carefully cut to size beforehand and must be deburred or sanded properly. Sealing is advisable, especially for MDF, to prevent swelling from moisture. Painting or applying a wood stain works well for this purpose.
Alternatively, thin multiplex boards can be used; these are somewhat more durable than MDF but may be more challenging to work with.
Ultimately, the choice depends on the intended use – for purely aesthetic purposes and light to moderate load, MDF is a practical option.
bente
16 Aug 2019 20:11
Jaime schrieb:
It is important when fastening that the material is secured according to the load requirements.
I really like how you explained it so thoroughly! I also tried working on a Kallax and did a bit of experimenting because I found the thin back panel wasn’t very sturdy. For me, it turned into a bit of a patience game in the end, as precisely cutting the pieces was not so easy, and at first, I was worried about damaging the shelf.
As Fredlo mentioned, screws or small brackets are great because they allow you to make adjustments if needed. I initially fixed my panel with double-sided tape and then secured it with small nails—it holds really well, even if it doesn’t sound very professional. I didn’t want a permanent adhesive bond so I could potentially restore the shelf to its original condition when moving.
However, you should make sure that the new material is not too heavy, or the stability will suffer—for MDF in a thinner thickness, this can be well controlled.
Overall, I felt really comfortable with my Kallax—it feels more stable now and looks more customized, which is especially great if you use the shelf as a room divider. I’m keeping my fingers crossed that your project turns out as well as you hope! 🙂
