ᐅ Kallax back panel cannot be glued – alternative fastening methods?
Created on: 9 Sep 2020 14:23
barnu
barnu
9 Sep 2020 14:23
I recently bought a Kallax shelf from Ikea and wanted to secure the back panel with construction adhesive to make it more stable. However, the adhesive does not seem to bond properly to the back panel – it either does not set at all or the panel comes loose again after a short time. I find this a bit surprising because normally a fiberboard panel should hold well enough with construction adhesive.
My question is:
Are there alternative methods or options to permanently and securely fix a Kallax back panel in the shelf without using screws or nails? Maybe specific adhesives or other fastening techniques that have proven effective here?
I would appreciate any experiences, tips, or tricks you can recommend. Thanks in advance!
tra_nina
9 Sep 2020 15:07
Hello barnu,
First, a brief explanation of your issue: The back panel of the Kallax is usually made of thin fiberboard, which is either painted or coated. This reduces the surface adhesion of mounting adhesives, which generally work better on porous or rough surfaces.
Alternatives:
1. Special wood glues with good adhesion to laminate/fiberboard (e.g., PU glue) might work.
2. Mounting brackets or small screws at the edges provide mechanical fastening and are relatively unobtrusive.
3. Double-sided tape (very strong, e.g., from 3M) for temporary fixing.
4. Hot glue can help with thin back panels but does not hold up well long-term.
My advice: If a permanent and stable fix is desired, small screws or brackets are definitely the safest solution. Adhesives alone are often problematic with this type of material.
Timofa
9 Sep 2020 15:58
tra_nina schrieb:
Adhesive alone is often problematic with this material.
Oh yes, you’re absolutely right! I’ve also come across thin back panels on IKEA shelves that just don’t accept glue properly.
What worked really well for me was this "little secret weapon": expanding foam! It sounds a bit wild at first, but if you press the back panel lightly, the foam expands slightly and provides a secure hold. Of course, be careful not to use too much, or else it can expand too much 😉
Otherwise, I can only agree with you: screws or small brackets, maybe set a little inward, are the most stable solution.
But hey, a bit of improvisation can be fun too, right? 🙂
neoren
10 Sep 2020 09:12
I would simply recommend using small nails. They are inexpensive and can be driven in quickly. You don't need to worry about splintering; with a hammer and a light touch, it works perfectly without causing any damage.
Alternatively, double-sided tape can be used if it isn’t subject to heavy loads.
refinar
10 Sep 2020 11:37
Here is a brief guide with tips on how to secure a Kallax back panel:
1. Preparation: Clean the back panel and shelving unit thoroughly, removing any dirt or grease.
2. Adhesive: As mentioned, neoprene-based contact adhesive can provide better adhesion than construction adhesive, especially on painted surfaces.
3. Mechanical Fixing:
- Use small metal angle brackets (about 10 x 10 mm (0.4 x 0.4 inches)) secured with screws at the corners.
- These are usually barely visible from the outside and offer excellent stability.
4. Optional: Use high-strength adhesive tape for additional support.
5. Installation: After applying the adhesive, clamp the back panel in place with clamps or grips until the adhesive cures (at least 24 hours).
Common mistakes:
- Applying adhesive on very smooth, painted surfaces without preparation.
- Not pressing the adhesive firmly enough.
Conclusion: A combination of adhesive and mechanical fixing ensures the most durable hold.
pautanner
11 Sep 2020 08:46
neoren schrieb:
Small nails are inexpensive and quick to set
That has always worked well for me too. I use very small, fine pin nails that leave hardly any visible holes. And if you want it even finer: pre-drill with a drill and then drive the nails in to prevent any splitting.
Timofa schrieb:
Assembly foam as a secret weapon
Interesting idea, I haven’t tried that before – do you have a specific foam in mind or just regular expanding foam?
Jokes aside, you really can’t beat classic screws and brackets. But sometimes a bit of creativity is welcome. 😉
Best regards!
