ᐅ Is KALLAX too delicate to use as a workshop cabinet?
Created on: 5 Oct 2015 07:34
tutous
I am planning to use the IKEA KALLAX unit as a workshop cabinet to neatly store my tools and smaller equipment. However, I have often heard that the KALLAX is considered somewhat too delicate in terms of stability and durability for workshop conditions. My question is: Is the KALLAX really too sensitive for the harsher environment of a workshop, including exposure to moisture, dust, occasional impacts, or the weight of heavier tools? Or is its construction and material quality sufficient to use it effectively as a workshop cabinet with appropriate precautions?
I look forward to your assessments and experiences!
LANELE
6 Oct 2015 09:11
tutous schrieb:
I have been considering reinforcing the individual compartments with shelves to better distribute the load.
That makes sense, but also check the back panel. It is often crucial for stability. If it is not reinforced, the cabinet can tip over or twist.
SETHBLA
6 Oct 2015 12:18
If you want to store really heavy equipment, the KALLAX is not ideal. Also, consider whether there might be a more suitable workshop cabinet. The KALLAX is primarily designed for light to medium loads in living rooms or workspaces.
O
ONCARTER
7 Oct 2015 08:55
Regardless of its appearance, the KALLAX is a shelving unit made of laminated particleboard that offers a certain load capacity but has some weaknesses for workshop use:
- The material thickness and edges are sensitive to mechanical stress.
- The joints are designed for minimal screw diameter and dowel pins.
- The surface finish can withstand moderate moisture but is not suitable for long-term exposure in a workshop environment.
Recommendation: If you want to use the KALLAX in a workshop, you should consider additional reinforcements, such as metal brackets at the base and extra cross supports. Furthermore, a protective coating or a plastic cover is advisable to prevent dirt and damage. Otherwise, damage may occur.
Tause
7 Oct 2015 11:23
I see this as a critical issue. A workshop cabinet must withstand mechanical stress over the long term, not just occasional pressure. The KALLAX is not designed for such demands. Modifications are only a compromise, not a substitute for robust planning.
PULAU
8 Oct 2015 07:42
That’s the key point. For lighter use, you can certainly use the KALLAX, but for professional or intensive use, sturdier furniture should be chosen. For most home hobbyists, the KALLAX with additional reinforcements is sufficient.
