ᐅ After taking apart the furniture, my Kallax shelving unit loses its stability – any tips?
Created on: 11 May 2021 09:23
SIPAR
I recently assembled an Ikea Kallax shelf unit, which I had to take apart after a while and then reassemble in a different location. However, I noticed that after disassembling, the shelf no longer has its original stability. It wobbles noticeably more, feels less sturdy, and is generally less secure for placing items on it. I followed the assembly instructions correctly, but even after reassembling, it seems less robust than before.
Are there any specific tips for improving the stability of a Kallax after it has been taken apart and put back together? Maybe tightening screws, using different connection methods, or adding extra reinforcements? Or is the material simply too susceptible to repeated assembly and disassembly? I want to avoid the furniture becoming unsafe if possible. Thanks in advance for your advice!
SIPAR
11 May 2021 13:01
blapau schrieb:
replace, if possible, screws and wall plugs with new ones
Thank you for this advice; I hadn’t considered that since I thought it wasn’t a big deal.
BeAndrea schrieb:
reinforce with double-sided tape
That sounds unusual at first, but it might be worth trying for the adhesive bond.
jeff65 schrieb:
use wooden dowels with a slightly larger diameter
Then I would have to widen the holes a bit, right? Would that be safe so the shelf doesn’t crack later if I make the holes bigger?
I’m also unsure since the Kallax has relatively thin panels. Are there other mechanical reinforcements you would recommend?
One additional question: Is the bottom shelf crucial for stability? I thought it only serves as a divider; maybe I should secure it better?
Katan
11 May 2021 14:07
Cool question! The Kallax doesn’t have traditional back panels, so its stability mainly comes from precise slot connections and screws.
SIPAR schrieb:
Any other mechanical reinforcements you’d recommend?
A good idea is small corner brackets, like simple metal angles from the hardware store. They add a lot of strength and are hardly visible, especially when mounted on the back sides.
And yes, the bottom shelf can improve stability if it fits tightly. You can reinforce it further with small wooden dowels or screws. Kind of like a stabilizing skeleton 😉
If wobbling is annoying, a combination of light reinforcements and new material at the joints often helps.
PULAU
11 May 2021 15:41
The stability often suffers from small errors during assembly.
For Kallax, I recommend aligning all connections before fully tightening the screws and then gradually tightening them to avoid creating any tension.
Also check whether the edges fit together properly, especially with the plug-in joints. Even a slight misalignment can reduce stability.
LOSAR
12 May 2021 08:46
One more tip: Additional spacers in contact with the ground can be helpful. If the floor is uneven, place the shelf on small plastic feet or felt pads – this prevents wobbling.
REOHEINRIC
12 May 2021 09:14
To systematically improve stability, I recommend the following steps:
1. Check the fit of the dowel holes and replace the dowels if necessary.
2. Tighten all screws with appropriate torque—not too tight to avoid material breakage.
3. If needed, add metal brackets at the corners on the inside to keep them visually discreet.
4. Use wood glue on the dowels for a lasting bond.
5. Ensure a level base, using adjustable feet or felt pads if necessary.
Together, these measures will help keep the shelf safe and stable, even after multiple assemblies and disassemblies.
