Hello everyone, I would like to start a discussion on the topic of “How stable is the IKEA Kallax shelf when placing a fish tank on it?”
My question is specifically about whether the Kallax can reliably support the weight of a water-filled tank over extended periods without sustaining long-term damage or creating safety risks.
I understand that water is relatively heavy: 1 liter weighs about 1 kg (2.2 lbs), and a small to medium aquarium can quickly hold 50 to 100 liters (13 to 26 gallons) or more, which means 50–100 kg (110–220 lbs) of water weight alone, not including the tank itself and any equipment.
Does anyone have experience with this kind of load? How does the stability of the shelves and the quality of the materials hold up? Are there any special tips or reinforcements that should be applied?
I look forward to your answers and discussions!
Hello nafo69,
Regarding the stability of the Kallax shelf with a fish tank, I can share some insights since I have been using this shelf myself for years—although not with an aquarium, but with heavier items. Basically, the Kallax is a modular shelf made of medium-density fiberboard (MDF) with a relatively thin coating. It can handle loads, but the official maximum weight capacity per compartment is about 13–15 kg (29–33 lbs).
If you want to place an aquarium on it, the critical factor is how the weight is distributed. A 50-liter (13-gallon) tank weighs around 50 kilograms (110 lbs) plus its own weight, plus the equipment, so easily 60 kg (132 lbs) or more. It is unrealistic for a single compartment to support that load flexibly and safely.
Here are some technical details to consider:
1. Load distribution: Ideally, the weight should be spread over multiple compartments or the base reinforced.
2. Stability: The shelf is not designed for “wet” loads, as water damage can quickly soften and weaken the MDF panels.
3. Reinforcements: Additional screws or metal brackets under the shelves increase the load capacity. Also, placing a thick plywood sheet as a base on the shelf can help.
How large is your tank exactly? Have you already assembled the shelf, or are you still planning to acquire it?
Hey nafo69 and everyone else,
I agree with Domau0 – the Kallax is really practical, but using it as a base for an aquarium can be a bit of a challenge ;-)
I once had a 40-liter (10.5-gallon) tank on it, and my advice is: don’t do it without extra reinforcements. I cut a plywood board to size and screwed sturdy metal brackets underneath.
The advantage is that the weight is distributed much better, and you won’t have to worry about the shelves bending or, in the worst case, swelling. Plus, with such reinforcement, you can significantly increase your peace of mind – just so you sleep better at night 😉
Have you had similar experiences?
flo-Theres6 Oct 2024 10:22A practical tip for stability:
If you use the Kallax shelving unit for an aquarium, it is recommended to place a sturdy baseboard under the tank. This can be a thick MDF or plywood board, which helps distribute the weight more evenly and reduces point loads on the shelf.
Additionally, the shelving unit should be securely fixed to the wall to prevent tipping. The load from an aquarium filled with water and equipment creates a significant continuous stress, which can be particularly problematic for older or already stressed Kallax units.
For smaller nano aquariums up to 20 liters (5 gallons) without equipment, I do not see any major issues. For larger tanks, reinforcement and caution are necessary.
Domau0 schrieb:
How large is your tank exactly? Have you already assembled the shelf, or are you planning to buy it?Thank you for the detailed response. The tank I have in mind holds about 60 liters (approximately 60 kilograms) when empty of equipment.
I have already assembled the Kallax shelf; it is the standard 4x4 model (16 compartments). I plan to place the aquarium in two of the lower compartments, directly on the bottom panel of the shelf, not on the individual shelves.
It is important for me to consider not only short-term load capacity but also a safe solution designed for many years. Hence my question about possible reinforcements and also any experiences regarding long-term stability.
