ᐅ How much weight can typical KALLAX shelves actually support?
Created on: 15 Aug 2023 09:17
leoteo53
Hello everyone, I am currently considering getting a KALLAX shelf unit from IKEA and have a question that concerns me beforehand: How much weight can the typical KALLAX shelves realistically support when installed normally and without additional reinforcement?
I am specifically interested in practical experience and official information about how much weight the shelves can handle in everyday use without bending or damage. I want to know if it is safe to store somewhat heavier items like stacks of books, devices, or boxes on these shelves – or if it is better to plan for lighter loads.
Perhaps someone here has reliable practical experience or well-researched material data? Thanks in advance!
Thierryzar
17 Aug 2023 08:48
I placed 20 kg (44 lbs) on a KALLAX shelf, and it held for several months without visible damage. However, I know this is more of an exception. It is important that the weight is evenly distributed.
If you regularly store heavy items, you should be careful and consider using more sturdy shelving.
Aimee
17 Aug 2023 09:21
Thierryzar schrieb:
I had 20 kg (44 lbs) on a KALLAX shelf, and it held for several months without visible damage.
That can work if the load is well distributed. However, this is close to the material’s limit. For long-term use with that much weight, I still recommend reinforcement.
leoteo53
18 Aug 2023 07:55
Thank you again to everyone for the detailed posts and helpful advice. I now have a good overview of the load limits and reinforcement options.
In summary, I understand that KALLAX shelves generally support a maximum of about 13-15 kg (29-33 lbs) – with point loads or sustained heavier weights, bending is likely, and structural damage may be possible. Reinforcements such as brackets or wooden slats are recommended for heavier loads.
This is very helpful for my planning. I will definitely use reinforcements for the heavy items. Thanks to everyone who shared their experiences! 🙂
