ᐅ Which threshold values are critical when modifying KALLAX tables?
Created on: 30 Jun 2017 10:17
rolujo
I am currently working on modifications of IKEA KALLAX tables, where the original shelf panel structures are altered. I have the question: Which threshold values should be critically considered for such KALLAX table modifications? By this, I mainly mean mechanical load capacities such as maximum load limits, material thicknesses, and potential points where stability or safety could be significantly compromised – for example with cutouts, alterations to joint connections, or changes in span lengths.
I am looking for experience-based assessments or technical advice on which values should definitely not be exceeded during planning to ensure the table remains safe and stable in the long term. It would be great if you could share your experiences or solid knowledge on this!
An important factor for fixed-end spans is the clear span. Thicknesses are usually around 1.5 cm (0.6 inches) of material, but the critical span typically occurs at about 60 cm (24 inches). If the clear span between two reinforcements exceeds this, the wood tends to bend quickly.
Therefore, I recommend:
- Clear spans under 60 cm (24 inches)
- Additional cross braces if exceeded
Regarding metal reinforcements, at least 2-3 mm (0.08-0.12 inches) thick brackets or plates should be used, carefully connected to the wood structure to absorb shear forces.
In short: Thresholds for fixed-end length, material thickness, and reinforcement go hand in hand.
rolujo schrieb:
Are there any practical experiences regarding how much additional reinforcement is advisable?Yes, that is crucial! I am currently building a gaming desk using KALLAX units – and 3 mm (0.12 inch) thick metal brackets have proven very useful for me. I attached them on the inside at the critical edges and secured them with at least 4 screws per bracket.
This not only feels sturdy but also effectively absorbs vibrations and loads. Without this reinforcement, larger cutouts or heavy weights would have been problematic.
Additionally, the reinforcements should be placed within the last 10–15 cm (4–6 inches) of the span so that the load distribution is optimal.
reoWilhelm1 Jul 2017 08:44Great topic here! :-) I’d like to add some information about load-bearing, especially concerning cutouts or openings for cables or devices:
One threshold I’ve observed is the maximum deflection: a maximum of 5 mm (0.2 inches) deflection over a length of 60 cm (24 inches) is a good guideline. That looks stable and feels solid.
Also, the choice of fasteners is crucial – some flat-pack furniture often uses dowels and particleboard joints, which can fail quickly under loads over 12 kg (26 lbs) per shelf. Screws work better in these cases.
One more tip: you can also add small braces with wooden strips on the sides, which significantly increases stability!
For the load, plan for no more than 12 kg (26.5 lbs) per compartment.
The material thickness of the panels must not be less than 1 cm (0.4 inches).
Large cutouts should only be made with additional reinforcement.
Avoid spans over 60 cm (24 inches), otherwise collapse may occur.
tangi schrieb:
Clear spans under 60 cm (24 inches)reoWilhelm schrieb:
Maximum deflection of 5 mm (0.2 inches) over a length of 60 cm (24 inches)That sums it up perfectly! I think this is a very useful guideline for people like me who are not professional woodworkers yet.
I would also like to know: How about the stresses at the edges? Are there critical values for the load on bearing surfaces? This also includes tabletops placed on the KALLAX shelf as a table.
I assume that distributing the load over the largest possible bearing area is part of the stability equation?
rolujo schrieb:
How about the stress on the edges?Oh yes, that’s definitely something you shouldn’t underestimate! 🙂
KALLAX has relatively thin edges covered with melamine foil – the material tends to tear quite quickly if too much pressure is applied at a single point. So: try to distribute loads as evenly as possible, create rounded edges, and avoid drilling holes with sharp edges.
If you place something heavy on it, it’s best to put an additional board on top as a “buffer” to spread the pressure more evenly. This way, you avoid critical point loads and the table will last significantly longer.
