ᐅ Using a Kallax as a TV Stand: Does Side Load Make a Difference?
Created on: 18 Nov 2022 10:37
maufo
I have been considering using an IKEA Kallax shelf as a TV stand for some time. My main question is: "Does the lateral load on the Kallax shelf really make a noticeable difference in terms of stability and safety for a larger TV?"
I have heard different opinions. Some say that the Kallax units are relatively stable due to the open back and construction, as long as they are properly secured to the wall. Others believe that the lateral load—that is, the weight and leverage the TV applies to the upper side surfaces—can be problematic and may cause deformation or even tipping over in the long run.
Specifically, I am interested in any experience-based information about how much lateral load the shelf can actually handle when placing, for example, a 50-60 inch TV (approximately 20-30 kg [44-66 lbs]) on top or positioning it slightly angled.
Maybe someone can also share insights on the difference between a free-standing shelf and one attached to the wall regarding lateral stability.
Thanks in advance for your feedback!
angel
19 Nov 2022 11:35
Hello maufo,
I would like to add that the load from the TV involves not only its weight but also vibrations and movements – for example, when children are playing nearby or someone bumps into the shelving unit.
Therefore, wall mounting is not only helpful to prevent deformation caused by lateral loads but also to ensure stability against unexpected forces.
If you cannot secure the shelving unit to the wall, I recommend distributing the weight evenly across several shelves and avoiding additional loads on the sides.
Additionally, for large TVs, adjusting the TV’s feet so that the load is distributed as evenly as possible across the shelves can help, as point loads can cause problems.
I hope this helps! 🙂
KNUTGI
20 Nov 2022 08:48
Genevieve schrieb:
Are you planning to reinforce the back panel of the Kallax, or just use the standard construction with wall mounting?
Maufo, just as an idea: depending on your DIY skills, it can help to reinforce the back panel with a plywood sheet. This distributes the forces better and makes the unit much more stable. I tried this myself, and afterwards the shelf was rock solid – like a proper piece of furniture rather than just a simple shelving box. 😉
Alberto51 schrieb:
After several months, my TV started pressing noticeably against the side edge.
Yes, I’ve noticed that too. From experience, I’d say it doesn’t happen overnight, but the effect adds up if you don’t take countermeasures.
So, just going by instinct: better be safe than sorry if you’re placing a heavy TV on it. And especially if you have kids who might shake the shelf! ;-)
