ᐅ Using a Kallax as a TV Stand: Does Side Load Make a Difference?
Created on: 18 Nov 2022 10:37
maufoHello everyone,
I have been considering using an IKEA Kallax shelf as a TV stand for some time. My main question is: "Does the lateral load on the Kallax shelf really make a noticeable difference in terms of stability and safety for a larger TV?"
I have heard different opinions. Some say that the Kallax units are relatively stable due to the open back and construction, as long as they are properly secured to the wall. Others believe that the lateral load—that is, the weight and leverage the TV applies to the upper side surfaces—can be problematic and may cause deformation or even tipping over in the long run.
Specifically, I am interested in any experience-based information about how much lateral load the shelf can actually handle when placing, for example, a 50-60 inch TV (approximately 20-30 kg [44-66 lbs]) on top or positioning it slightly angled.
Maybe someone can also share insights on the difference between a free-standing shelf and one attached to the wall regarding lateral stability.
Thanks in advance for your feedback!
Hey maufo,
“Does side load really make a difference for the Kallax shelf?” – great question! 😄 I’ve been using my Kallax as a TV stand for years, and I can say: yes, you can definitely feel the side load. Especially when the shelf is freestanding and heavier equipment is placed on top.
That’s absolutely right, wall mounting really makes a big difference. My tip: if wall anchoring isn’t possible, make sure to secure the shelf at the bottom and top with angle brackets to reduce the risk of tipping.
And very important: Kallax shelves are not designed to withstand significant lateral pressure. If the TV stand surface is too large or the TV too heavy and slightly tilted, the edges of the side panels can start to bend after some time. So it’s better to leave a bit more space from the side wall and distribute the weight evenly.
Looking forward to hearing what others might add from their experience. 🙂
maufo schrieb:
That the Kallax units are fairly stable due to the open back, as long as you secure them to the wall.
Maufo, the most important thing is wall mounting. Without a secure wall connection, you risk tipping over.
Lateral load can cause deformation if the weight is too heavy, especially with large TVs over 40 inches.
My advice: maximum 30 kg (66 lbs), place the TV as centrally as possible.
Genevieve18 Nov 2022 13:47The question about the lateral load on the Kallax shelf is valid and should be considered in detail.
This gets to the core of the issue, as IKEA itself states that Kallax is designed for lighter loads, primarily vertical pressure. The side load acts like a lever force, stressing the connections at the spacers. With continuous pressure beyond its intended limits, the wood can warp or the joints can loosen.
However, the weight you mentioned (20–30 kg (44–66 lbs) TV) is not necessarily critical – what matters most is how the TV is placed, whether the load is distributed evenly or concentrated in one spot.
My question for you: Do you plan to reinforce the back panel of the Kallax or just use the usual construction with wall anchoring? And what about additional devices (receiver, soundbar, etc.) in terms of load?
It is important to consider the total weight and how it is distributed, as this is crucial for durability.
KNUTGI schrieb:
Kallax shelves are not designed to withstand extreme side pressure.
Alberto5118 Nov 2022 15:22I understand your concerns, especially considering that a lot of valuable equipment is placed on the Kallax. I also had doubts about stability until I firmly secured my shelf to the wall. That immediately gave me much more confidence and relieved my fear of it tipping over.
I experienced something similar to you: my TV (about 55 inches, 27 kilograms (60 pounds)) started to noticeably press against the side edge after several months, even though I only had light speakers and a few books inside.
It’s also important not to underestimate that occasional pushing or leaning can further affect the feeling of stability. I recommend, if possible, adding a small reinforcement inside or at least checking it regularly.
The Kallax is very practical overall, but with a larger TV, you shouldn’t be too careless. Planning for this difference definitely makes a noticeable impact.
A more technically precise answer:
The Kallax shelf is made from particleboard with a melamine coating, which provides good surface stability but is relatively limited in thickness. The load capacity on one side is limited by the joint surfaces inside (these cross braces).
Lateral loads create leverage forces that cause stresses at edges and joints. Over time, this leads to material fatigue and potentially to bulging.
The greater the cantilever distance forward (for example, if the TV slightly extends beyond the edge), the higher the bending moments.
Securing the shelf to the wall is therefore practically relevant and virtually necessary if the shelf is to maintain its shape under lateral load.
Conclusion:
1. Maximum TV weight about 30 kg (66 lbs), place it centrally.
2. Be sure to fasten the Kallax to the wall to prevent tipping.
3. Additional side reinforcements would be advisable for particularly heavy or asymmetrical loads.
This way, you can significantly extend the lifespan of the shelf.
Conclusion:
