ᐅ KALLAX and Moisture Directly on the Exterior Wall – What Are the Risks?
Created on: 21 Sep 2023 08:37
Doraiden
Hello everyone, I have a question regarding “KALLAX and moisture directly on an exterior wall – what risks are involved?” Specifically, I want to know if there are any health or structural risks when placing an IKEA KALLAX shelf directly against an exterior wall that sometimes releases moisture to the surface, for example due to poor insulation or condensed air. I am wondering if the moisture could cause long-term damage to the furniture, if mold could develop, and whether this might lead to damage to the wall or even health problems for the occupants. It would be great if someone could assess the risks and maybe provide some tips for prevention. Thank you very much in advance!
kasan
21 Sep 2023 14:56
Doraiden schrieb:
In cold weather, the wall may appear damp, but it is not visibly wet.
This sounds like the wall is not truly dampened by moisture but rather experiencing condensation due to unfavorable temperature and humidity conditions – which is a completely different issue than capillary moisture or rising damp.
A KALLAX shelf made of particleboard is sensitive to moisture, as already mentioned. The main risk is moisture condensing behind the shelf, causing the humidity to remain there longer.
An important question is: How close is the furniture placed to the wall? And is there regular ventilation? Since you mention that the area is ventilated and there is no high humidity, the risk seems lower.
Additionally, consider whether the shelf will stay in that spot permanently; short-term placement should be unproblematic.
My recommendation: keep some distance from the wall and ventilate regularly. If visible moisture increases, consider waterproofing measures on the wall.
Of course, one should also ask whether investing in furniture made from moisture-sensitive material near a potentially damp exterior wall is the best choice.
retau
22 Sep 2023 07:08
kasan schrieb:
The main risk is that moisture condenses behind the shelf and stays there longer.
That’s exactly what I wanted to highlight!
Creating a gap allows air circulation – and that helps the wall to dry out moisture more quickly.
I have a similar setup in my house and simply place small wooden strips under the shelf to allow air to reach the back. It really helps a lot!
For extra protection, you could also consider attaching a thin moisture barrier mat to the wall, which absorbs the moisture and lets it evaporate.
It’s amazing how simple measures like these can protect both furniture and walls! 🙂
