ᐅ Is there any accessory available for retrofitting Ikea PLATSA doors?
Created on: 11 Feb 2024 18:23
fernando56F
fernando5611 Feb 2024 18:23Hello everyone,
Lately, I’ve been looking into the Ikea Platsa systems and bought a few basic components. Now I’m wondering if there is any special accessory for the PLATSA doors that can be added to make them more functional or visually appealing. Specifically, I’m interested in things like better soft-close hinges, alternative handle options, or perhaps door dampers that Ikea doesn’t provide as standard.
Does anyone in the community have experience or tips on whether certain accessories are really worth it for PLATSA doors, especially if you want to improve functionality? Or are the original Ikea components already good enough? I would appreciate detailed feedback, particularly regarding the compatibility of third-party accessories and any notes on specific differences between the various PLATSA door types.
Thanks in advance for your help!
Regarding accessories for Ikea PLATSA doors, it can be said that Ikea itself offers only a limited range of spare parts and accessories, focusing mainly on original replacement parts for the standard hinges and handles.
- Hinges: PLATSA doors often use Ikea’s standard butt hinges or clip-on hinges, but soft-close versions are not always included as standard. However, there are third-party suppliers offering compatible door dampers that slow closing and reduce noise. Fit is generally good, but it is advisable to compare measurements before purchasing.
- Handle options: Ikea provides its own handle variants, but alternative handle bars and knobs from specialized furniture fittings suppliers can also be installed. It is important that the drilling holes on the PLATSA doors match the new handles or are adapted accordingly.
- Additional accessories: Magnetic catches can be retrofitted to ensure the doors close firmly. Special door dampers combined with the hinges are also possible, although installation may require some DIY skill.
In summary, retrofit accessories are available but often supplemented by third-party providers. It is recommended to measure the original parts carefully and check any compatibility notes from the accessory manufacturer.
warrenka5712 Feb 2024 08:36Paxton38 schrieb:
For the hinges: PLATSA doors often use the standard butt hinges or clip hinges from Ikea, but the soft-close versions are not always included by default.That’s an important tip, thank you for sharing! Personally, I found it helpful to equip the doors with additional door dampers from the hardware store. At first, I wasn’t sure if they would fit properly, but with a little patience, installation went smoothly.
I completely understand that small improvements like these can make a big difference, especially if you use the doors frequently and the slamming noise is really bothersome. Maybe someone else here is uncertain whether the retrofit is worth the effort—I can say that for me, it definitely feels noticeably better.
It’s also important to me that such retrofits don’t require too much effort or complicated modifications, especially if you want to preserve the original PLATSA design. However, if you’re looking for open handles or more customization, you should be able to make some adjustments even if they’re not officially supported by Ikea.
warrenka57 schrieb:
That’s an important note, thanks for that!You’re welcome. To add, when retrofitting door dampers, it’s essential to carefully check the mounting points on the hinges or doors to ensure stability and avoid damage.
I have also noticed that the market for accessories for IKEA systems like PLATSA has grown in recent years. Various suppliers now focus on modular upgrades such as improved hinges, magnetic door openers, or minimalist handle strips. These are often specifically tailored to the dimensions and design of IKEA products.
However, I recommend caution with very inexpensive third-party products that lack clear specifications. These can cause fitting issues or reduced durability. For those who want to be on the safe side, using replacement parts or accessories offered directly by IKEA is advisable, even if options are limited.
For ambitious DIYers, custom solutions using fittings from the furniture hardware sector might also be interesting, provided there is experience with precise installation and accurate workmanship.
