ᐅ Is there a guide on how to equip an IKEA BESTA unit with additional casters (wheels)?
Created on: 21 May 2024 10:07
Linneaon
Linneaon
21 May 2024 10:07
Hello everyone, I currently have an IKEA Besta sideboard without casters and am wondering if there is any guide or proven method to equip this piece of furniture with additional wheels. My main question is: Is there a practical and appropriate way to make the BESTA series mobile without compromising its stability or appearance? I am especially interested in the type of wheels (locking casters vs. simple swivel wheels), the possible attachment methods to the cabinet body, as well as advice on weight limits or necessary reinforcements. If anyone has already done this or has experience and recommendations, I would greatly appreciate detailed tips.
fiman
21 May 2024 10:24
You can easily equip IKEA BESTA units with furniture casters. It’s best to use casters with screw mounts. Pre-drill holes in the bottom panel and securely screw in the casters. Make sure the maximum load capacity of the casters matches the weight.
Kinbu
21 May 2024 11:36
Hello Linneaon, I think your question is very relevant since the mobility of furniture is often underestimated. Many caster models generally offer different weight capacities, which is important because IKEA BESTA units are often loaded quite heavily. It is essential that the casters are attached underneath the cabinet, ideally on the base panel, which should be sturdy enough to support the weight. If you cannot find suitable drilling points, you can also use reinforcements, such as thin wooden panels screwed inside to the underside, and then attach the casters to them. If you want locking casters, I recommend paying close attention when ordering to ensure the casters can be locked easily. If you like, I can give you some tips on what to consider when choosing them.
Lorukeo
21 May 2024 13:59
The BESTA series from IKEA was originally designed without casters, so there is no official IKEA guide for retrofitting wheels. Nevertheless, adding furniture casters works well if you keep the following points in mind:
- Load capacity: Each caster should support at least 20 kg (44 lbs), as a fully loaded BESTA unit can easily weigh 80-100 kg (176-220 lbs).
- Attachment: The most secure method is to install the casters on the bottom wooden panel, fastening them with sufficiently long screws.
- Preparation: If the base panel is too thin, it should be glued or reinforced with mounting battens to prevent screws from tearing out.
- Appearance: Adding casters to the underside of the furniture can change its look. Low-profile casters are recommended as an option.
In summary, there is no official guide, but following these precise steps allows for a proper and effective retrofit.
Davidleo
22 May 2024 08:15
Great that you’re working on this! I equipped my BESTA with casters, and it’s so much fun to move the modules around flexibly!
I used simple swivel casters with metal mounts and screwed them to the corners of the base panel. I made sure the casters have brakes so the furniture doesn’t roll away all the time! 👍
My tip: definitely pre-drill the screw holes a little to prevent the wood from splitting! Also, check the load capacity of the casters when buying them, otherwise you won’t be able to load the furniture as you want. Good luck – it works great!
Franck
22 May 2024 10:48
The easiest option is wheels with screw fastenings, which you attach to the base plate. Don’t forget to pre-drill. I recommend wheels with built-in brakes. Be careful when assessing the weight – IKEA furniture can get heavy.
