ᐅ Is there a guide on how to equip an IKEA BESTA unit with additional casters (wheels)?
Created on: 21 May 2024 10:07
Linneaon
Hello everyone, I currently have an IKEA Besta sideboard without casters and am wondering if there is any guide or proven method to equip this piece of furniture with additional wheels. My main question is: Is there a practical and appropriate way to make the BESTA series mobile without compromising its stability or appearance? I am especially interested in the type of wheels (locking casters vs. simple swivel wheels), the possible attachment methods to the cabinet body, as well as advice on weight limits or necessary reinforcements. If anyone has already done this or has experience and recommendations, I would greatly appreciate detailed tips.
Jukin
23 May 2024 09:33
Good morning Linneaon, I agree with the other posts and would like to add a few more details:
If you want to equip the Besta with casters, it’s helpful to carefully plan their positions before attaching them. They should be mounted at the four corners of the base panel to ensure even load distribution and allow for stable, wobble-free rolling. Alternatively, if stability allows, you can also install additional casters in the middle of the sides.
Regarding the casters, swivel casters with a locking function are a good choice so you can securely fix the furniture after moving it. Attachment is usually done with wood screws; I strongly recommend pre-drilling to prevent the base panel from splitting. For added stability, you can place a thin plywood sheet under the furniture panel to hold the screws.
I hope this helps with your project!
flo-Theres
23 May 2024 14:22
Linneaon schrieb:
Is there a practical and material-suitable guide on how to make the BESTA series mobile without compromising stability or appearance? I am particularly interested in the type of casters (locking casters vs. simple rolling casters), mounting options on the cabinet body, as well as information about weight limits or necessary reinforcements.
To answer your question precisely: There are no official instructions from IKEA, so a custom solution is required. The main challenge is attaching the casters to the bottom panel, which in the BESTA series is often only about 12 mm (½ inch) thick, making secure screw mounting difficult.
For mounting, I recommend adding an extra wooden strip or plywood panel beneath the existing bottom panel. This provides a stable base for fixing the casters. When choosing casters, look for a load capacity of at least 20-25 kg (44-55 lbs) per caster and preferably opt for locking swivel casters if both mobility and stability are needed.
To preserve the look, I also suggest selecting low-profile casters that remain as discreet as possible.
Josefane
24 May 2024 17:06
Davidleo schrieb:
I equipped my BESTA with casters, and it’s so much fun to move the modules around flexibly!
That sounds tempting, but have you checked how the casters affect everyday stability? Especially with IKEA furniture, which isn’t designed for frequent load movements, this could lead to faster material fatigue.
Also, I wonder if it might be better to select the casters carefully instead of just using standard furniture casters. Are the screws recessed deeper into the wood, or are there supports that help distribute the pressure?
I consider it important not only to focus on practical handling but also on long-term durability and safety. Are there any studies, tests, or experience-based evidence that prove this modification is safe over time?
