ᐅ Is there a guide for installing sliding doors on Ikea Pax wardrobes?
Created on: 1 Jan 2023 08:27
putatau
I recently purchased an Ikea Pax wardrobe and would like to install sliding doors on it. The doors should run smoothly and be sturdy, as I want to save space in front of the wardrobe. My question is whether there is a widely available and detailed guide for installing sliding doors on the Pax systems?
I’m especially interested in details such as mounting the tracks, aligning the doors, and the recommended tools for the job. Perhaps some of you have experience or sources that make it easier to approach the installation, as so far I have only seen the Ikea instructions for the standard doors.
I look forward to helpful tips and possibly advice on whether there are different sliding door models to consider. Thanks in advance!
Here is a brief overview of the best approach for installing sliding doors on Ikea Pax wardrobes:
Step 1: Unpack and sort all components and fittings
Step 2: Mark the drilling holes for the running rails and mounting points
Step 3: Precisely align and attach the upper and lower running rails to the cabinet frame
Step 4: Insert the doors with the rollers into the rails
Step 5: Adjust the doors using the adjustment screws to optimize gaps and smooth operation
Step 6: Perform a final check and readjust if necessary
Common mistakes I often see:
- Running rails not aligned perfectly horizontally, causing the doors to be difficult to move
- Confusing the upper and lower running rails
- Tightening screws too quickly before the doors are properly positioned
My advice: Stay calm and proceed step by step. This helps avoid rework or issues with sticking doors.
Thank you for all the helpful responses here! I had a bad experience myself when I tried to install the sliding doors without precise instructions.
You really underestimate how accurately the tracks need to be aligned. It was quite frustrating at first.
That’s so true. You shouldn’t rush the process.
If anyone has tips for fine-tuning the doors, please share! I think I still need to make some adjustments.
Peose schrieb:
Take plenty of time, it’s not rocket science, but rushing will cost you nerves.
Thank you all for the detailed information and encouraging words!
I especially appreciate the small step-by-step guide from sinhau. That seems to be exactly what I needed to get a clear plan.
I’m also curious whether there are major differences in the installation of the various Pax sliding door models, or if the system is mostly the same?
Additionally, are there any limitations regarding the maximum door width or door height that should be used for sliding doors to ensure smooth operation? Thanks again!
