ᐅ Is there a simple way to round off the edges of IKEA BESTA panels?
Created on: 6 Jul 2023 10:37
YvodanIs there an easy way to round off the edges of IKEA Besta units?
I’m planning to refine an IKEA BESTA cabinet, specifically by rounding its sharp edges to make it not only more visually appealing but also safer for everyday use. I’m looking for a practical and straightforward method that isn’t too time-consuming and doesn’t require specialized professional tools. Has anyone had experience with gently rounding the edges of the BESTA system without damaging the surface or involving a lot of effort? I would appreciate any tips, including tools or techniques that have proven effective.
Rounding the edges of the IKEA BESTA system is definitely doable, but there are some important points to keep in mind to achieve a satisfactory result.
First of all: The edges of the BESTA system are usually covered with a thin PVC or melamine edge banding, not just plain wood. If you sand these edges without proper care, the coating can crack or unsightly spots may appear.
My advice: Use a fine sanding sponge or a small sanding block to evenly work the edge. Work in multiple steps with different grits (for example, 180 to 320). This way, you avoid removing too much material and keep the surface smooth.
It would also be helpful to know how much rounding you want. A slight rounding (also called "breaking the edge") is relatively easy, while a more pronounced curve requires more effort and patience.
One more tip: Some people use a tool called an edge planer or a file to shape certain radius edges easily. Afterwards, sand again.
One last question for you: How experienced are you with tools and sanding work? Do you need a method that is as safe and simple as possible, or are you open to more advanced tips?
Palenar schrieb:
If you sand these edges without proper preparation, the coating might crack or unsightly spots could appear.This is an important point that is often underestimated. Before working on the edges, you should be clear about the material’s structure. Simply rounding off the edges seems practical, but it changes the functionality of the edge, especially with plastic coatings.
You should consider whether the visual effect or safety is the priority – and whether there are alternative solutions, such as soft edge protection profiles.
Additionally, I find the discussion about long-term benefits missing – how durable is a rounded edge when the coating is compromised? Are there any experiences regarding whether the wood panel becomes less stable or more susceptible to moisture as a result? This is particularly relevant for furniture like BESTA, which is used in living areas.
I’m happy to provide a simple guide on how to round off IKEA BESTA edges relatively easily and neatly – with a bit of patience and the right tools.
1. Preparation: Clean the edge thoroughly to ensure no dirt particles interfere during sanding.
2. Tools: It’s best to use fine sandpaper (grit 240 or higher). A small sanding block helps to work the edge evenly.
3. Technique:
- Start with light pressure and always sand along the edge’s direction; avoid cross-grain movements as they can damage the coating.
- To properly round the edge, sand all three sides (top, bottom, and front) with small, controlled movements.
4. Finishing: If possible, seal the edge with a color-matched paint or clear lacquer to protect the material and keep moisture out.
Common mistakes:
- Using sandpaper that is too coarse (this can tear the coating).
- Applying uneven pressure, which results in an irregular surface.
In summary:
- Work cleanly
- Use fine sandpaper
- Sand in small sections
- Don’t forget to reseal
If you tell me which tools you plan to use, I can offer more specific advice.
3. Technique:
Common mistakes:
In summary:
- Work cleanly
