ᐅ Is there a trick to assembling the Ikea Brimnes furniture without any help?
Created on: 3 Feb 2019 08:38
emindra
emindra
3 Feb 2019 08:38
Hello everyone, I recently bought an Ikea Brimnes bed and now face the challenge of assembling it on my own. My question is: Are there any real tips, tricks, or proven methods to safely and effectively put together the Brimnes bed, especially the larger and somewhat bulky parts, without help? I have already gone through the instructions, but I find that some steps, particularly when standing the bed upright, are difficult to manage without extra hands. Has anyone had experience with this and can share advice on how to handle the assembly alone without risking damage to parts or becoming overwhelmed?
LAURE-TA
3 Feb 2019 10:26
Hello emindra, I know the Brimnes bed and can tell you from experience that assembling it without a second person is definitely possible if you keep a few tricks in mind. Here is a short guide:
- Preparation: Lay out all the parts in an organized way so you immediately know where each piece belongs. A neat layout saves a lot of time and confusion.
- Prepare the screws and fittings: It’s best to put screws and dowels into small bowls or cups so you don’t lose anything.
- Important: Some steps require patience and a bit of improvisation. For example, when setting up the bed frame, it helps if you loosely screw in some hinges or connection points first – this allows the wood some flexibility.
- A trick I always use: apply strong tape strips or wedges to temporarily hold parts in place when you don’t have a second hand.
- For standing the frame up: if possible, lean the larger panel against another surface (e.g., a wall or wardrobe) before fully tightening the screws. This makes handling much easier.
If you have any questions about a specific step, feel free to ask. I documented the assembly process step by step and can provide targeted advice.
kepunau
3 Feb 2019 11:14
LAURE-TA schrieb:
Use sturdy tape strips or wedges to temporarily hold parts in place when you don’t have a second pair of hands.
I think that’s a really smart suggestion! 😊 I’d like to add that patience is key. Assembling a piece of furniture alone is like a small expedition – with the right tools (like a screwdriver, clamps, tape) and a good sense of humor, it goes much more smoothly.
It’s also important to take enough breaks and not rush. Especially the Brimnes furniture is sturdy, but if you press or tilt too hard, parts can shift. So work calmly and carefully, and you’ll manage just fine on your own!
Z
zardi
4 Feb 2019 07:22
If you don’t have any help, make sure to work close to the ground and loosely assemble all large parts first. This way, you’ll have more flexibility when fitting the pieces together and can handle the parts more easily on your own.
LAURE-TA
4 Feb 2019 09:46
zardi schrieb:
Make sure to work close to the ground and initially screw all large parts together only loosely.
That is exactly a very good tip! Especially the loose preliminary assembly often makes the crucial difference.
In addition, I would suggest placing rollers or sturdy boxes underneath to make it easier to turn and move the wood. This also allows the heavy headboard of the Brimnes bed to be handled more easily on your own.
And: Always keep the instructions handy – sometimes a second look at the sequence helps before tightening everything completely.
