ᐅ Is there a simple way to close Ikea Metod drawers quietly?
Created on: 20 Dec 2023 07:12
Adelbertma
Adelbertma
20 Dec 2023 07:12
I have a question that has been on my mind for a while, and I’m hoping someone in this forum has practical experience or smart tips: Is there a simple way to close Ikea Metod drawers quietly?
I’ve noticed that when closing Metod drawers, there is often a surprisingly loud bang or slam, which can be very annoying, especially in quiet moments. I have already checked that the drawers fit firmly and are correctly installed, but I can’t completely eliminate the noise.
I’m particularly interested in simple and inexpensive solutions—whether mechanical dampers, special padding, or some type of additional components—that can be easily attached to the Metod drawers without major modifications or needing advanced technical skills.
I look forward to your suggestions and maybe even experiences that go beyond the standard recommendations.
V
Vinlen
20 Dec 2023 10:37
Hello Adelbertma,
your question is well formulated and very precise. For the issue with the loud closing of Ikea Metod drawers, there are indeed some options that are relatively easy to implement.
One of the most common solutions is the installation of silicone or felt dampers, which are attached either to the drawer side or to the cabinet body. These effectively reduce the noise and are simple to apply, often with a self-adhesive backing.
Alternatively, there are so-called "soft-close" retrofit mechanisms, often designed as small spring or gas dampers, that significantly quiet the closing. These are somewhat more expensive but quite easy to install if you are familiar with the standard slides of Metod drawers.
If you like, I can provide more technical details about the different types of dampers or tips on installation and replacement.
Laukau5
20 Dec 2023 14:03
Hello Adelbertma,
To fully answer your question, "Is there an easy way to close Ikea Metod drawers silently?" I would like to go into more detail, since the drawer slides play an important role in noise management, especially with Metod systems.
Background: Metod drawers often use roller and metal slide rails, which tend to produce mechanical noise. Here are some points that might help you:
- Check if the drawer slides are clean and free of dirt or residue, as these are common causes of noise.
- Lightly lubricating the metal parts with silicone spray can reduce noise levels, but it won’t guarantee complete silence.
- Applying self-adhesive rubber or felt pads at the contact points between the drawer and the cabinet can effectively reduce rattling. Positioning is crucial here: usually on the rear support points or on the sides where the contact is strongest.
- Soft-close mechanisms, which some aftermarket suppliers offer specifically for Metod slides, are naturally the best solution because they slow down the closing action and thus almost eliminate noise. However, installation isn’t always “easy,” as existing slides often have to be completely replaced.
My question to you: Have you already checked which slide systems are installed on your drawers? This makes it much easier to recommend retrofit solutions.
I suggest trying the felt pad option first, as it is the quickest and most cost-effective step.
Nabla64
21 Dec 2023 09:58
Hello Adelbertma,
I would like to offer a structured approach that has proven to be practical and effective in making Ikea Metod drawers close completely silently:
1. Analysis of the noise source:
- Open the drawer and check where metal or wood parts hit each other and cause the noise.
- Often, small plastic stops or rubber bumpers are missing or worn out.
2. Selection of suitable dampers:
- Soft silicone pads that can be self-adhesively attached inside the back of the drawers.
- Felt pads on the inside of the cabinet sides to reduce metal contact on the drawer slides.
3. Retrofitting a "soft-close" function:
- Compatible soft-close modules for Metod are available from Ikea and third-party suppliers.
- These modules are especially useful if the drawer is used frequently and a consistently pleasant user experience is desired.
4. Installation tips:
- Ensure that the Metod drawers are precisely aligned to avoid uneven stress and the resulting noise.
- Clean the drawer slides thoroughly before attaching the dampers.
5. Practical advice:
- When using self-adhesive dampers, clean the surface with alcohol beforehand to ensure long-lasting adhesion.
- For older drawers, consider replacing the stop parts, as they can break or deform over time.
In conclusion, I recommend first addressing the cause of the loud banging, since a damper alone has only limited effect without proper alignment.
If you like, I can gladly prepare a checklist and sources for the necessary parts.
U
usJamie
21 Dec 2023 13:46
to close Ikea Metod drawers quietly, the following usually helps:
- Stick self-adhesive felt or rubber pads on the corners.
- Attach plastic or silicone dampers to the back of the drawers.
- If necessary, clean and lubricate the drawer slides.
This is often enough to minimize slamming.
Regards
Laukau5
22 Dec 2023 08:22
usJamie schrieb:
Stick-on felt or rubber bumpers in the corners.
That gets to the core, but I would like to add that the placement of the bumpers is very important. Not every corner is equally effective. For Metod drawers, the top back corner of the drawer is especially recommended, as this is where it hits the most.
Exactly, here you should install soft, flexible dampers at the right height to gently absorb the impact energy.
Another idea, which is particularly helpful for older drawers: you can slightly adjust the rails so that the drawer closes with less force or a lighter closing pressure. However, this can be a bit fiddly and isn’t possible with every model.
I’d be interested to know exactly how your drawers are currently installed, Adelbertma.
