ᐅ Is there a simple way to close Ikea Metod drawers quietly?
Created on: 20 Dec 2023 07:12
Adelbertma
I have a question that has been on my mind for a while, and I’m hoping someone in this forum has practical experience or smart tips: Is there a simple way to close Ikea Metod drawers quietly?
I’ve noticed that when closing Metod drawers, there is often a surprisingly loud bang or slam, which can be very annoying, especially in quiet moments. I have already checked that the drawers fit firmly and are correctly installed, but I can’t completely eliminate the noise.
I’m particularly interested in simple and inexpensive solutions—whether mechanical dampers, special padding, or some type of additional components—that can be easily attached to the Metod drawers without major modifications or needing advanced technical skills.
I look forward to your suggestions and maybe even experiences that go beyond the standard recommendations.
V
Vinlen
23 Dec 2023 16:11
Laukau5 schrieb:
The rails can be slightly adjusted so that the drawer closes with less impact or requires less closing force.
I would also recommend this, but only if you are familiar with the system. The Metod system in particular often has small adjustment screws that allow you to align the drawers smoothly and precisely.
Furthermore, I would like to point out that regular inspection and cleaning of the rails significantly improves operation and often reduces noise without any further measures.
If you want to make your drawers especially quiet, you should consider investing in installing Ikea’s “soft-close” system or compatible retrofit options. This offers the most reliable solution for noiseless closing.
Otherwise, gentle padding and small dampers, as already mentioned, are a good first step.
