ᐅ Is there a kit available for retrofitting door handles on Ikea PLATSA units?
Created on: 2 Nov 2022 08:37
margherita
margherita
2 Nov 2022 08:37
Hello everyone, I have a question regarding the Ikea Platsa furniture series: Is there an official or unofficial set of door handles that can be retrofitted to the PLATSA cabinet doors? I find the handles available at Ikea somewhat limited in terms of selection and functionality, and I would like to know if there is a practical retrofit kit that can be easily installed, and whether this kit fits all PLATSA doors universally or only specific models. Additionally, I am interested in recommendations for alternative handles that can be mounted on PLATSA doors without much effort. Thank you in advance!
Naomige
2 Nov 2022 10:19
Hello margherita, I completely understand your situation. PLATSA is very flexible, but not in every detail. Regarding your question: IKEA does not officially sell separate retrofit sets with handles specifically for PLATSA. Most users choose to use the standard IKEA furniture handles that are compatible with the pre-drilled holes.
The most important information is that PLATSA doors have standardized drill holes for handles or knobs that you can use. These holes usually have a 64 mm (2.5 inch) center-to-center spacing, which fits common furniture handles. This allows you to retrofit almost any standard handle.
A few tips:
- First, measure the hole spacing on your PLATSA door precisely
- Make sure the screw length matches the door thickness
- If the doors do not have holes, you can drill them yourself, but this must be done carefully
Alternatively, many people use simple knobs or magnetic handles that can be mounted without drilling – however, this may result in a slightly different appearance. If you like, I can share some examples that have worked well for other users.
O
ODINFLO
2 Nov 2022 13:05
Naomige schrieb:
Ikea officially does not sell separate retrofit kits with handles specifically for PLATSA.
I consider this to be crucial. What I often see as a concern is that users expect Ikea to offer complete accessory sets for every piece of furniture, even though the product range is intentionally kept minimalistic.
Therefore, one should fundamentally ask whether adding handles to PLATSA is meant to be a custom modification. The hole spacing on PLATSA doors follows a common standard size, which ensures compatibility with many handles.
Naomige schrieb:
If the doors don’t have holes, you can also drill holes yourself
Here I strongly recommend caution. Not everyone has the right tools or experience to drill holes precisely. Incorrect drilling can damage the door or result in an impractical appearance.
My suggestion for anyone looking to retrofit: measure the door carefully before buying or drilling and possibly practice on a similar piece of wood first. Also, it is worth considering flexible handle types, such as clamp-on handles or grips that do not require drilling, although aesthetics and durability may be compromised.
JAFUHAU
3 Nov 2022 09:24
I find the discussion here very helpful and would like to add that many users also look for and try out custom solutions for aesthetic reasons.
I was also bothered by the limited selection of handles for PLATSA at Ikea, so I bought separate handles from a furniture store that matched the hole spacing exactly. It was important to me that the handles are sturdy and comfortable to hold.
Some forum members have also had success with handles from hardware stores that allow flexible installation, such as recessed handles or handle strips that can be glued or screwed onto the top edge of the door.
One small drawback, however, is that not every retrofit option is guaranteed to fit the stable door mechanism, since PLATSA sometimes uses thinner door materials. This can cause problems if the screws are too long or the handles are too heavy.
Finally, a tip for everyone: Ikea offers magnetic push-to-open systems for PLATSA without handles, in case you want to avoid handles and prefer a minimalist look.
