ᐅ Is there a guide for retrofitting soft-close mechanisms on Ikea BESTÅ doors?
Created on: 8 Oct 2024 08:13
dwayne
Hello everyone, I am wondering if there is a guide or at least a practical method to retrofit IKEA BESTÅ doors with a soft-close function. The doors on my existing furniture do not have built-in soft-close mechanisms, and I would like to know if it is possible to modify the current doors to include soft-closing, ideally without having to replace the hinges entirely or make large holes. Does anyone have experience with this or know of a step-by-step guide that is practical and doable for DIY enthusiasts? Thanks in advance!
I upgraded my BESTÅ doors with soft-close hinges from IKEA. Just replace the hinges, adjust if needed, and you’re done. The drill holes usually fit perfectly; if not, minor adjustments are possible. I tried adhesive dampers, but in the end, they were not a truly satisfactory solution.
sanjon schrieb:
I retrofitted my BESTÅ doors with soft-close hinges from IKEA. Just replace the hinges, adjust, and you're done.Thanks, that sounds very helpful! Did you use the original IKEA hinges? And were there any technical issues, for example due to material differences in older furniture or wear and tear?
Yes, I used the original IKEA soft-close hinges. For older stock, you should check if the drill holes match before purchasing; this is the most important point. If the piece of furniture is reasonably intact, the replacement goes smoothly. Material wear can affect the fit, but this is rarely a major issue.
Summary for anyone looking to retrofit the soft-close feature on IKEA BESTÅ doors:
- The best option is to replace the old hinges with original or compatible soft-close hinges.
- Check hole compatibility to avoid unnecessary drilling.
- Soft-close dampers mounted inside the cabinet are possible but not always ideal due to positioning precision.
- Common tools are required for installation, such as a screwdriver, and possibly a drill and drilling template.
- Note that slight adjustments may be necessary for older models.
I recommend verifying the exact model series and measurements before purchasing individual parts.
tra_nina schrieb:
Check hole compatibility to avoid unnecessary drilling.Exactly. This is the crucial point when retrofitting because IKEA’s model specifications can vary. I would also advise dwayne to fully remove the hinges and use a tape measure to record the hole positions. Then you can accurately calculate whether a direct replacement is possible or how much adjustment effort is required. If you like, dwayne, you can share the exact measurements of your current hinges and cabinet profiles here.
Thank you for the constructive and detailed contributions. I will take precise measurements of the doors and hinges again and then try to obtain the original soft-close hinges from IKEA. If I encounter major obstacles, I will get back to you with specific questions. Many thanks to everyone for the tips!
