ᐅ Is the Pax system also suitable for storing heavy winter clothing?
Created on: 9 Feb 2020 18:42
Wilhelmi34
Wilhelmi34
9 Feb 2020 18:42
I am currently looking into whether the Pax dryer is suitable for heavy winter clothing such as thick down coats, ski jackets, or heavily lined wool coats. It is important for me to know if the drum size and the dryer programs of the Pax are adequately designed to gently and reliably dry such bulky and sometimes very delicate garments. Has anyone already had experience with this or can provide insights regarding care or potential damage?
I am particularly interested in whether drying performance is affected by a high load or thick material structure, and if any special settings are recommended. Thanks in advance for your help!
Ianlau
9 Feb 2020 19:17
Hello Wilhelmi34,
First of all, I think your question is very reasonable, as heavy winter clothing often presents a challenge for tumble dryers. Depending on the model, the Pax dryer has different drum sizes, which are generally designed for average household loads.
Basically, it is important to use a program with reduced temperature and possibly a special “gentle cycle” for down jackets and similar bulky items to avoid damaging the delicate filling materials.
It is normal for drying performance to decrease with very full loads because warm air cannot circulate optimally. One tip is to dry heavy garments individually or with a small load per cycle to ensure even drying.
Additionally, anti-crease or refresh programs can be used when the clothing is only slightly damp to protect the fiber structure.
If you like, I can also provide a brief guide on how to optimally dry your winter jackets in the Pax dryer?
refinar
10 Feb 2020 08:04
Ianlau schrieb:
The Pax dryer features different drum sizes depending on the model, typically designed for average household loads.
This is an important point because with heavy winter jackets, not only the drum size matters but also the program and the type of drying.
I would like to provide a brief structured overview on how to generally handle heavy winter garments:
- Check the drum size: For very large and bulky items, it is better to dry them individually to avoid bottlenecks in air circulation.
- Keep the temperature low: Down insulation loses its effectiveness if exposed to high temperatures.
- Use special programs: Programs for outdoor or down jackets are useful if your dryer offers them.
- Plan for gentle drying times: It is better to dry longer and more gently rather than quickly and aggressively.
- Measure moisture: If your device has a moisture sensor, it is an advantage to prevent overheating.
Common mistakes include overcrowding the dryer, using too high temperatures, or selecting completely inappropriate programs.
Summary: In general, the Pax is suitable for heavy winter clothing if you follow these points. However, it always depends on the specific model and the care instructions of the clothing.
Jatau
10 Feb 2020 12:51
Pax is suitable for heavy winter clothing, as long as you don’t overfill it and use a gentle cycle. Otherwise, material damage or uneven drying may occur.
Palenar
11 Feb 2020 09:38
Wilhelmi34 schrieb:
I am currently considering whether the Pax dryer is suitable for heavy winter clothing such as thick down coats, ski jackets, or heavily lined wool coats.
To answer this question properly, it is important to know exactly which Pax model you are referring to, as the devices vary quite a bit in their technical specifications and available programs. A few key points you should definitely keep in mind:
- Drum capacity: For heavy, bulky clothing, a drum volume of around 8 kg (17.6 lbs) or more is recommended to ensure sufficient air circulation.
- Drying technology: Condenser dryers tend to be gentler, while vented (or exhaust) dryers can be somewhat harsher.
- Program selection: Programs like "Down," "Outdoor," or "Wool Finish" indicate that the manufacturer has considered the need to treat sensitive, thick materials carefully.
- Sensor control: Modern moisture sensors can prevent overheating and thus protect the fibers.
An important factor is the type of filling in the winter clothing. Down, for example, is very sensitive to heat and compression. The fibers can clump together and lose their insulating properties. Regular shaking during drying is therefore important.
Wool, in contrast, must not be dried at too high a temperature because it can shrink or become misshapen quickly.
My recommendations:
- Dry heavy jackets individually or at most two items per load.
- Use special programs with low temperature and longer drying time.
- Carefully check your Pax user manual for advice regarding delicate materials.
If you like, I can provide you with a detailed guide on how to dry very heavy winter clothing based on your exact model. It is worthwhile to adapt the process precisely to the material properties; otherwise, you risk damage and reduced lifespan of your garments.
