I am currently planning to set up a walk-in closet and am considering whether the Ikea PAX system is really suitable for this purpose. My requirements are quite clear: I want flexible interior fittings, solid quality, and the easiest possible assembly. The closet should accommodate hanging rods, shelves, and drawers, and be adaptable to different room sizes. Has anyone had experience with using PAX as the basis for a walk-in closet, and is it truly practical, or are there better alternatives? I am particularly interested in the stability, storage capacity, and versatility, as I need not only simple wardrobe solutions but also a customized setup tailored to my needs.
I think PAX is great for a walk-in closet project – you can basically customize every part to fit the room perfectly. 😎 Plus, there are always suitable interior fittings that add real value. And if something doesn’t fit? Just buy a few boxes or baskets to add personality to the whole setup!
PAX is technically suitable for walk-in closets if the exact room dimensions are known and precise planning is carried out. The modules are standardized with a maximum height of 236 cm (7 ft 9 in), which must be considered in rooms with higher ceilings. The maximum load per shelf is approximately 25 kg (55 lbs), so caution is advised when storing heavy footwear or heavier items. Additionally, attention must be paid to securing the modules to the wall to ensure stability. In general, I recommend using the PAX planner to try out possible layouts before purchasing to avoid mistakes.
I equipped my walk-in closet with PAX and was initially unsure about the stability. In everyday use, everything is sturdy, and the flexibility of the interior is very enjoyable. It was important for me to combine enough drawers and open shelves. However, I would have liked more ventilation options, as air sometimes gets a bit trapped in closed cabinets.
