ᐅ Is it possible to build a terrace with natural stone slabs on a concrete foundation?
Created on: 14 Mar 2021 14:43
Sebastian F.
Sebastian F.
14 Mar 2021 14:43
We would like to build a terrace with natural stone slabs and currently have the following structure (13 years old):
  • Compacted recycled material
  • Concrete slab 18 cm (7 inches)
  • Sloped screed (only 1% incline!) with reinforcement and waterproof membrane under the screed
  • Porcelain tiles glued on top
  • Aluminum profiles at the edges
The aluminum profiles have become loose over time, and some edge tiles are also loose and/or broken.
We now want to build a terrace with natural stone slabs and have the following plan:
  • Remove the porcelain tiles
  • Grind the sloped screed to increase the slope to 2-3%
  • Install a studded drainage membrane (studs facing up, overlapping layers like roof shingles)
  • Spread at least 3 cm (1 ¼ inches) of basalt premium gravel on top and level it at a 2% slope
  • Lay the slabs loosely on the gravel
  • Install edge stones
Our questions are:
  • Is it possible to lay natural stone slabs on gravel over a concrete slab like this? If not, what would be the alternative?
  • Should or must a drainage fleece/geotextile be used? If yes, should it be placed directly on the drainage membrane or directly under the slabs?
  • Regarding laying slabs on gravel in general: Is there a risk that, even with a slope, moisture droplets will remain under the slabs permanently, and could that cause problems?
Thank you in advance for any answers!
P.S.: Total build-up height is not an issue for us.
FF2677
15 Mar 2021 10:05
Hi,
it is possible without a drainage membrane. What is important is a layer of gravel with at least 6cm (2.4 inches). And very important: use gravel size 5-8mm (0.2-0.3 inches).
Otherwise, you will get the well-known damp spots on natural stone. If unfamiliar, you can quickly look this up online.
Most people use gravel size 2/5mm (0.08/0.2 inches) or 0/5mm (0/0.2 inches), but these are not capillary-breaking. This is not a problem with concrete slabs, but with natural stone you will get the damp spots.
rick201815 Mar 2021 10:16
Or simply elevate.
Sebastian F.
18 Mar 2021 08:52
Thank you for your suggestions!
I think I will go with 5/8 inch crushed stone on a Dörken Delta MS dimple membrane with a slope. It can handle significant pressure/weight and is durable.
