Dear Ladies and Gentlemen,
Dear forum members,
The house construction is progressing, and I now need to start thinking about the terrace.
It will be a corner terrace (south-west facing) of about 90 sqm (970 sq ft).
The house description (scope of work) includes a gravel base with Jura gravel that ends approximately 20 cm (8 inches) below the finished terrace height, providing the option to add crushed stone or similar material.
I would like to install 90 x 90 cm (35 x 35 inches) R11 tiles with a thickness of 2 cm (0.8 inches).
Is it possible to lay them on crushed stone, and do I need so-called spacers or pedestals?
Thank you very much.
Dear forum members,
O
Osnabruecker10 Aug 2021 09:25In my opinion, gravel is only suitable for height adjustments of 3-5 cm (1-2 inches). If your builder constructs a layer of 20 cm (8 inches), you would still need to add about 12 cm (5 inches) of gravel in between, or have it installed higher right away.
A thickness of 1 cm (0.4 inches) breaks too easily. 2 cm (0.8 inches) is the standard.
Stefan89010 Aug 2021 09:41I don’t have personal experience yet. However, I was advised to use at least 3 cm (1.2 inches) slabs for installation on gravel. 1 cm (0.4 inches) slabs should be glued.
I have mentioned this elsewhere: our trusted tiler advises against using gravel and recommends pedestal supports instead. This is likely because larger tiles tend to be more prone to deflection.
