1
1234viele16 Oct 2011 23:37Hello,
A few weeks ago, I bought a discounted Pax wardrobe from IKEA – width 75 cm (30 inches) – and now I wanted to set it up in my new apartment and quickly buy doors for it. However, I found out that there are no doors available for this size at all!
Where can I still get doors???
Maverick185417 Oct 2011 07:04Where can I still get doors ????From the carpenter, but they will be surprised because there have never been doors for 75 cm (30 inches) wide cabinets. Just the size: 75 cm (30 inches) / 2 = 37.5 cm (15 inches) door or exactly 75 cm (30 inches).
IKEA-Experte17 Oct 2011 12:52And for those wondering what the 75cm (30 inches) wide carcass is used for, please refer to the "PAX Buying Guide for Sliding Doors," which can be downloaded from the website.
rafael196617 Oct 2011 15:32Hello everyone!
You have several options:
1.) Buy another one, and you will have a great sliding door wardrobe with a total width of 150 cm (59 inches). (Sliding doors need to be purchased separately.)
2.) Buy two hinged doors, each 40 cm (16 inches) wide, have them cut down to about 37.2 cm (14.6 inches) at the hardware store, and glue edge banding to the cut edges. (This is rather pointless since the fronts are usually more expensive than the cabinet carcass.)
3.) Have the horizontal shelves of the wardrobe cut to (60 - 1.8 - 1.8) or (50 - 1.8 - 1.8), which is 56.4 cm (22.2 inches) or 46.4 cm (18.3 inches), to create a wardrobe 60 cm (24 inches) wide (kitchen cabinet fronts) or 50 cm (20 inches) wide (PAX fronts). Where you have the shelves cut, you will need to use corner connectors, for example, because the standard IKEA mounting recesses will have been cut off. The same applies to the PAX back panel.
4.) Curtain
5.) Return it.
Tough choice – let us know which option you decide on!
4.) Curtain
5.) Return it.
rafael196617 Oct 2011 15:39Item 3) only applies if it is the smaller version, i.e., a height of 2.00 m (6 ft 7 in), since the maximum height of the front panels is 195 cm (77 inches).
Regards
Regards
Maverick185417 Oct 2011 16:125.) return.... does not apply, as reduced...
