ᐅ When is it worthwhile to choose IKEA Pax wardrobes over other brands?
Created on: 29 Sep 2024 08:22
Nanu3
Hello everyone, I am currently considering whether buying an Ikea Pax wardrobe is really worthwhile compared to other brands, particularly from different perspectives such as value for money, quality, design flexibility, and durability. I understand that Ikea is mainly known for modular and relatively affordable furniture, but how does the Pax wardrobe perform in terms of sturdy materials, customization options, and ease of repair compared to other suppliers that are often more expensive? I am interested in learning: When is an Ikea Pax wardrobe a smart choice, and when is it better to go for another brand? Are there any experiences or useful criteria you can recommend to help assess this better?
dijan
29 Sep 2024 11:55
I think Pax hits the mark if you enjoy mixing and matching a bit and don’t want to spend a fortune right away. Sure, it’s not the highest-end stuff, but hey, the wardrobe basically grows with you – need more storage? Just add on! Kind of like Lego for adults ?.
GALEO4 schrieb:
Mass-produced goods you see everywhere.
Sure, you could see it that way, but you also get a lot for your money. Quality versus quantity – this strikes a pretty good balance.
juMira46
30 Sep 2024 07:44
For me personally, the biggest advantage of Pax is the design flexibility: you can choose colors and fronts, upgrade components, and adjust everything to the ceiling height. This is a huge plus, especially in small apartments.
nubar schrieb:
Pax is especially worthwhile if you value flexibility, can assemble it yourself, and are looking for good value for money
I agree with that. Additionally, I find the ease of assembly very convenient, even if you’re not a professional.
However, you shouldn’t expect a love of wood – it is standardized and made for the mass market. If you keep that in mind, there is little risk with Pax.
warrenka57
30 Sep 2024 09:18
I would like to add that besides the factual criteria, personal needs and expectations also play an important role. When I bought my Pax, a key factor for me was feeling confident about repairs and customer service – and Ikea met that well.
There are definitely times when the affordable yet practical system makes everyday life easier.
However, I also understand the concerns about individuality and material choice that GALEO4 mentioned, as I have had similar experiences.
My recommendation is to carefully consider how long you plan to use the wardrobe and whether sustainability is important to you. This way, you can better decide if Pax or another provider is the right fit.
Nanu3
30 Sep 2024 11:03
Thank you for the contributions so far! They help me look at the topic from different perspectives.
Especially the advice on the availability of replacement parts and the installation process has given me valuable insights.
One thing I am still curious about: Are there specific Pax models or accessories that have proven to be particularly recommended or problematic in practice? For example, with drawer systems or doors? This would help me plan the purchase more precisely.
fredle
30 Sep 2024 11:50
Good question, Nanu3! Here are a few specific tips:
- Drawers: Ikea usually uses metal sides with smooth gliding mechanisms for Pax, which are generally very reliable. However, the drawers should not be loaded too heavily to avoid wear.
- Doors: There are both hinged doors and sliding doors. Sliding doors require precise installation; otherwise, they tend to rub or scrape. Hinged doors are more forgiving, but the door stops and hinges may need occasional adjustment over time.
- Interior fittings: Clothes rails and inner drawers are well made, but you should ensure that shelves are properly seated and not overloaded.
In general, I recommend working carefully during assembly and following the instructions closely. Common mistakes include incorrect screw depth or overtightening, which can affect stability.
Lorukeo
1 Oct 2024 08:09
I would like to add that the sliding door system used in Pax wardrobes is especially sensitive if the tracks are slightly bent or not installed completely level. This can later cause noises and uneven movement.
Therefore, careful preparation of the installation site is crucial to avoid these issues.
User reports also indicate that the standard surfaces are particularly prone to scratches with extended use. To prevent this, it is recommended to choose high-gloss fronts or other more durable options when purchasing.
