ᐅ Ikea Pax Uggdal drawers cannot be pulled out
Created on: 10 Nov 2010 20:55
Ing
Ing
10 Nov 2010 20:55
This week I installed the 2.50m (8 ft 2 in) wide Pax UGGDAL wardrobe.
So 75 * 50 * 50 * 75.
Today I wanted to install the drawers, but I found that the drawers in the 50cm (20 inch) deep sections can’t be fully pulled out because the doors don’t slide open far enough.
However, it’s only about 2–3mm (0.1 inch) short, and the drawer would clear if it could open just a bit more.
Does anyone know what might be causing this?
Thank you
Maverick1854
11 Nov 2010 06:26
Is it the same on both sides or only on one side? Normally, it should work. Check again to see if there is any play or movement when sliding the rails.
Ing
11 Nov 2010 10:45
Yes, it’s the same on both sides.
Nothing is blocking the lower tracks; at the top, there is just this one plastic part (picture 1), but that is supposed to be there, right? I really don’t see anything I could work on 🙁
To help clarify, I took a few pictures:
Edit: I think the issue is resolved, the doors were not aligned correctly. I’m going to hang them perfectly straight now and hope that solves the problem 😉
