Is there a guide or a reliable method to adjust Ikea Metod drawers yourself? Specifically, I want to know how to set the drawers so that they run as straight as possible without sticking or wobbling. I have the impression that many drawers in the system slightly catch or don’t close completely flush after assembly. Are there simple steps for this, perhaps some kind of calibration that can be done by yourself? I would like to work through it systematically, but I don’t know if Ikea has special adjustment screws, hidden catches, or tricks that I might have missed.
Tevin schrieb:
If the drawer sticks, check that all the slide rails are free of dirt and nothing is obstructing the track. This is important. Often, it doesn’t stick due to adjustment issues, but because crumbs or small debris are caught in the rails.
Thank you for the previous tips; they have been very helpful.
I have one more question for clarification: When I adjust the front, I usually turn two screws on the right and left. Does this allow me to correct the tilt or only the height? Is it also possible to slightly rotate the front so that, for example, one side projects a bit further forward to achieve an optimal fit?
Yes, with Metod drawers you can slightly adjust the front by setting the left and right screws differently. This allows for minor angle corrections if the front is not completely flush.
It is important to adjust the screws carefully and in small increments, repeatedly reinserting the drawer and checking how it closes in between adjustments.
