ᐅ Ikea Metod: How can I build cabinets precisely and securely under sloped ceilings?
Created on: 2 Jan 2022 08:23
misozar
Hello everyone, I am planning to install new kitchen cabinets and tall cabinets from the Ikea Metod system in my attic. My challenge is that the roof slopes have different angles, and I want to fit the cabinets as precisely as possible to these inclines without them looking unstable or poorly finished.
Who has experience with building cabinets for sloped ceilings in a precise and sturdy way? How do you measure the angles, what adjustments to the Metod cabinets are necessary during installation, and which fasteners or anchors do you recommend to ensure the structure remains truly secure?
I am also interested in how you handle the appearance: Should special trim or cover panels be used to visually conceal any gaps? I appreciate any advice!
GU-LAU60
2 Jan 2022 13:33
CARLA schrieb:
Mounting: Secure the cabinets to the wall or sloped ceiling with sturdy brackets or heavy-duty anchors.
Exactly, without solid anchoring to the slope, nothing will really hold. The fastening is crucial.
If possible, also use clamps during installation to keep the parts in position.
misozar
3 Jan 2022 07:59
CARLA schrieb:
Appearance: Edge trims made of wood or MDF with matching decorative foil can be installed on the cut edges.
Thank you for the tip about the edge trims; I hadn’t considered that so far.
Does anyone have experience with flexible silicone joints? How durable are they when the wooden parts move? Would this really be a long-term solution, or do the joints tend to deform over time?
Giagau
3 Jan 2022 08:42
Silicone joints are generally flexible and can accommodate movement, provided the correct materials are used (neutral-cure silicone) and the joint width is properly sized.
However, the joint should not serve as a load-bearing element but only visually conceal transitions.
It is also important that the surfaces are clean, dry, and free of dust to ensure good adhesion.
GALEO4
4 Jan 2022 10:15
LIELCHEN schrieb:
Ikea Metod is not necessarily designed for sloping walls.
I want to revisit this point: For me, this is really the key issue.
The standard dimensions are limiting and make the work unnecessarily complicated if you have to deal with roof slopes that are never exactly 90 degrees or more.
I believe that despite all the advice, the best solution is a hybrid: Ikea fronts and doors combined with custom-made carcasses or at least self-cut components. This way, you gain more flexibility and can plan angles optimally.
jotisi
4 Jan 2022 11:03
GALEO4 schrieb:
Standard dimensions limit you and make the work unnecessarily complicated when you have to deal with roof slopes that are never exactly 90 degrees or more.
I completely agree. The great thing about Ikea is its modularity, but that often gets lost with custom sizes.
If precision is important, you either have to make significant compromises or invest. Adjusting for roof slopes basically means: "I either build it myself or invest in custom solutions."
