ᐅ IKEA Metod: How can I safely pack kitchen cabinets for a move?
Created on: 15 Aug 2023 10:23
lauro
lauro
15 Aug 2023 10:23
I am about to move and have a kitchen with IKEA Metod cabinets in my apartment that I want to transport safely. To avoid damage to parts or complications during reassembly, I am specifically looking for tips on how to best pack and prepare the kitchen furniture for the move.
Specifically, I am interested in:
- How should I secure or remove the cabinet doors and interior components?
- Are there special materials recommended for protecting surfaces and edges?
- Should the cabinets be fully disassembled or left partially assembled for the move?
- What is the best way to protect and store fragile parts like glass fronts or shelves?
I look forward to practical advice, experiences, or video recommendations you have on the topic "IKEA Metod: How to safely pack kitchen furniture for a move?" Thank you in advance!
KNUTGI
15 Aug 2023 11:02
lauro schrieb:
How should I secure or remove cabinet doors and interior elements?
Definitely: Removing them is usually better! Take off the doors and, if possible, unscrew the handles – this reduces stress during transport.
- It’s best to completely empty drawers and pack them separately.
- Interior components like shelves can be wrapped in bubble wrap and transported separately.
- For the surfaces, I recommend using a combination of furniture blankets and stretch wrap to prevent scratches.
lauro schrieb:
Should the cabinets be fully disassembled or is it better to leave them mounted as planned?
If you have the time and proper tools, dismantling individual modules helps a lot – especially for large cabinets, which can then be stacked more easily. But don’t worry if that’s too much; the furniture is quite sturdy. With the right padding, transporting them assembled works fine too.
A small extra tip: Label the parts and keep screws and fittings in small bags so nothing gets lost. This way you can avoid searching for replacement parts. 😉
All in all: Care and good preparation are essential. Good luck!
Joshbe
15 Aug 2023 14:47
For systematic preparation, I recommend the following approach when handling IKEA Metod kitchen cabinets:
- Remove doors and drawers and pack them separately with protective materials (e.g., stretch wrap and cardboard boxes to protect edges).
- Take out interior components such as shelves, as they can easily break during transport.
- Either completely disassemble the cabinet carcasses or, if that is not possible, carefully wrap them with furniture blankets and stretch wrap to prevent surface and edge damage.
- Collect screws and assembly hardware in labeled bags, ideally sorted by module.
For fragile parts like glass fronts or shelves, I suggest double padding: soft packing materials (foam, bubble wrap) plus sturdy boxes to prevent movement and breakage during transport.
Depending on your time constraints, fully disassembling the furniture is worthwhile, as transport will be easier and safer. For flat-pack furniture like Metod, clearly labeled individual parts contribute to a smooth reassembly.
In summary: careful planning, gentle disassembly, and targeted packaging are essential to avoid damage.
narDietmar
16 Aug 2023 09:38
Joshbe schrieb:
Depending on your time budget, it makes sense to completely disassemble the furniture, as this makes transportation easier and safer.
I can only agree with that. Especially the cabinets from the Metod series can be taken apart modularly, which saves a lot of stress during a move.
In addition, the following should be considered:
- Before disassembling, photograph all fittings and screws and sort them by part – this avoids confusion when reassembling.
- Protect the edges of sensitive cabinet doors and shelves with edge guards or foam padding.
- For glass elements, also use fragile cardboard boxes made of corrugated board.
lauro schrieb:
How should I secure or remove the cabinet doors and interior elements?
As mentioned before, doors and drawers should definitely be removed. This not only protects the individual components but also prevents damage to the main furniture body.
Using furniture blankets and stretch wrap is standard practice, but highly recommended for delicate surfaces.
I suggest thoroughly cleaning the furniture before packing to remove any grease or dirt, so the wrap or blankets don’t stick to the surfaces later.
