ᐅ IKEA METOD: How can I flexibly reconfigure kitchen cabinets?
Created on: 21 Jan 2023 08:34
Parkeo
Parkeo
21 Jan 2023 08:34
I am currently planning my new kitchen and have chosen the IKEA METOD system, mainly because of the apparent flexibility of the kitchen units. My main question is: How can I modify METOD kitchen cabinets as flexibly as possible if, for example, the room layout changes or I need different cabinet widths?
I am especially interested in how to best combine the various base cabinets, wall cabinets, and countertops to allow for easy adjustments later on. Are there any principles to follow or practical tips for implementation?
Additionally, I would like to know how stable such modifications are and how easy it is to disassemble and reassemble IKEA METOD furniture without compromising quality.
I look forward to your experiences and well-informed advice!
reni45
21 Jan 2023 10:12
Hello Parkeo,
In principle, the METOD kitchen cabinets are modular, which means you can remove or add individual cabinets without dismantling the entire system.
For flexibility, it is important to use standardized widths such as 40, 60, 80 cm (15.7, 23.6, 31.5 inches), as these combine well with each other.
Countertops can usually be easily cut or adjusted. During renovation, you should carefully loosen the fittings, and then it works smoothly.
kasan
21 Jan 2023 12:47
reni45 schrieb:
For flexibility, it is important to rely on standardized widths like 40, 60, 80 cm (16, 24, 32 inches), as these combine well with each other.
That's true, but I would like to add: flexibility doesn’t just mean swapping cabinets, but also redefining the placement of wall cabinets and countertop modules. The METOD system scores with its variable installation using frames and legs, but you should be careful not to distribute the weight of the components incorrectly.
Additionally, when remodeling, it is important to check the fastenings in the walls and floor. It is often underestimated that stability can be compromised during renovations if the fastenings are not properly removed and reinstalled. Otherwise, a loose countertop or uneven fronts are the usual consequences.
In conclusion: while it is possible to modify individual modules, in my opinion, you should carefully plan in advance which changes are likely. Frequent remodeling can cause material wear and is not unlimitedly possible without quality loss.
roryvin
22 Jan 2023 09:21
A flexible redesign of the IKEA METOD kitchen furniture requires both technical understanding and a careful approach.
Basics:
- The furniture is standardized in 20 cm (8 inches) modules, with standard widths of 20, 40, 60, and 80 cm (8, 16, 24, and 32 inches).
- Assembly is mostly done using cam lock screws and cam connectors, allowing for reversible assembly.
- Worktops are cut to size but can be shortened or adjusted if needed.
Conversion strategies:
- For maximum flexibility, it is advisable to choose standardized modules with identical depths to allow compatible fronts and worktops.
- The support structure and fastening system should always be realigned during a remodel to ensure stability.
- During disassembly, screws and fittings should be loosened carefully to avoid material fatigue.
Stability:
- METOD performs best under structural load when feet, walls, and connections are properly secured.
- Pay attention to load distribution: place heavy appliances in lower cabinets to minimize stress on upper cabinets.
Conclusion: Anyone looking to remodel their kitchen using METOD flexibly should first aim for modular planning that allows later changes in the setup without major interventions.
noge58
23 Jan 2023 19:13
Hi everyone!
I recently completely renovated my kitchen using the IKEA METOD system and can only say: it’s really fun because you have so many possibilities when redesigning! 👍
My advice: Make full use of the modular system, especially plan for sturdy connections using the connectors, and take your time when fixing it to the wall. For example, I swapped out fronts and cabinets several times—it was pretty easy because I only hung the cabinets without permanently fixing them.
I even cut the countertop twice, which was no problem with the right tools.
Even if you get help from a professional occasionally, you can do a lot yourself. However, you should definitely have a plan, otherwise you’ll quickly run into problems!
So: If you want flexibility, be sure to use the standardized dimensions and plan for more smaller modules rather than large ones that you can never move again.
