ᐅ How can I securely fasten IKEA Metod kitchen cabinets during renovations?
Created on: 19 Jul 2015 09:37
Annasan
Annasan
19 Jul 2015 09:37
Hello everyone, I am currently planning a renovation of our kitchen and have chosen IKEA Metod kitchen cabinets. My main question is: How can I securely and stably mount these kitchen cabinets during a renovation, especially when the wall surfaces for mounting are uneven or made of different materials (e.g., drywall and brick)? Are there specific screws, fastening techniques, or installation methods that have proven effective with Metod cabinets to ensure the cabinets hang safely over the long term without damage from stress? I would appreciate detailed tips or experiences, ideally including advice on what to avoid.
Elisa
19 Jul 2015 10:05
For uneven walls or different materials, I always recommend choosing appropriate anchors first. For drywall, cavity anchors are essential, while for brick, classic expansion anchors or hammer-in anchors are suitable. The Metod cabinet brackets come standard – if you secure them well with the right anchors, they typically hold firmly.
FABIAN_DEO
19 Jul 2015 11:12
Your question about secure mounting is very important, especially since Metod kitchen cabinets are subjected to different loads depending on the wall structure. I would like to suggest a detailed approach:
- First, be sure to check the wall materials and their load-bearing capacity. Drywall panels are only suitable for a limited amount of weight.
- For drywall, use special hollow wall metal anchors that can support high loads. Standard plastic anchors are often too weak.
- For solid walls (brick, concrete), choose expansion anchors or chemical anchors (injection mortar) if heavy loads are expected.
- Make sure the Metod cabinet brackets are installed perfectly level to avoid stress damage.
- For particularly heavy items, I recommend additionally screwing the cabinets from underneath.
- Before installation, always check the cabinets for optimal fit to ensure even load distribution on the wall.
If you like, I can provide you with a list of suitable anchors—just ask about your wall type.
bareynaldo
19 Jul 2015 12:44
FABIAN_DEO schrieb:
Metod cabinet brackets must be installed perfectly level to prevent stress damage.
This is something almost everyone underestimates. Instead of simply improvising, it’s important to first consider whether the wall can actually support more load than the cabinets require.
I find the huge enthusiasm for IKEA Metod during renovations somewhat exaggerated, especially if you lack prior DIY experience. The rigid standard often limits flexibility for custom mountings. For this reason, some prefer more traditional systems that allow greater tolerances with older walls.
klo40
19 Jul 2015 13:30
I would like to add to the discussion with a brief guide on how to securely mount a Metod cabinet system on uneven walls:
1. Check the wall: Determine the type of material, flatness, and load-bearing capacity.
2. Choose appropriate anchors: Use cavity anchors for drywall, expansion anchors for brick, and injection anchors for very heavy cabinets.
3. Attach the cabinet brackets to the wall at fixed distances. Use a spirit level to ensure they are horizontally aligned.
4. Screw the cabinet onto the brackets, paying close attention to millimeter distances to avoid pressure on the sides.
5. For extra stability, screw the cabinets to each other to prevent twisting.
Common mistakes:
- Choosing anchors that are too small or unsuitable.
- Installing cabinet brackets at an angle.
- Not using additional support for particularly heavy cabinets.
If anyone needs more information, feel free to ask.
Annasan
19 Jul 2015 15:16
FABIAN_DEO schrieb:
Metod cabinet brackets must be installed perfectly level to avoid stress damage.
That makes sense, thanks! What is the best way to measure the horizontal axis on slightly uneven walls? Is a simple spirit level sufficient, or would you recommend a more specialized method?
Also, I’m considering using Lywatt screws, which are said to work well with drywall – does anyone have detailed experience with these?
Regarding the last fixing idea: Do you think that in a standard kitchen the connection between the cabinets significantly reduces the main load, or is it more of an additional safety measure that can be seen as optional?
