ᐅ Precisely and Quietly Installing IKEA Metod Cabinet Doors
Created on: 11 Aug 2021 09:17
narjon
Hello everyone, I am currently facing the challenge of installing IKEA Metod kitchen fronts precisely and as quietly as possible. I find it particularly difficult to adjust the doors so that they close completely flush and do not make any noise when opening or closing. I am especially interested in whether there are proven techniques or tools that make precise alignment easier while also enabling silent closing. Are there any tricks for adjusting the Metod hinges or specific details to keep in mind to avoid wobbling, scraping, or creaking? I would appreciate detailed tips, ideally including advice on the best methods to align the doors with millimeter accuracy.
Layla
12 Aug 2021 11:34
I just want to say that I completely understand feeling pressured during installation to make everything perfect and absolutely silent. Especially with Metod, it can be very frustrating when, despite all the effort, an unwanted noise still occurs.
Maybe it helps to see it as a learning process and to stay patient instead of stressing too much. Every kitchen is a little different, and often the result is already very good if you follow the basic guidelines.
If you ever feel your patience running out, just take a break — it also improves precision and comfort while working.
DUVIN
12 Aug 2021 15:46
Press the dampers from IKEA into the hinges, adjust three times (height, depth, side), apply a small amount of silicone grease to the moving parts, done.
This procedure prevents creaking and ensures smooth closing.
TEBILO
13 Aug 2021 07:22
To mount the doors of the IKEA Metod kitchen precisely and quietly, I recommend a very systematic approach:
1. Preparation
- Lightly grease all hinges before installation, ideally with graphite or silicone grease, as these do not gum up.
- Lay out all door fronts on a level surface and check the drill holes.
2. Rough assembly
- Initially attach the doors loosely so they can still move easily.
3. Adjustment
- Carefully align the height using the top screw. Use a spirit level and compare with adjacent fronts.
- Adjust the lateral position with the designated screw to ensure even gaps.
- Adjust the depth with the third screw so the door sits flush with the cabinet carcass.
4. Test closing
- Check that the doors close without resistance or creaking. If needed, apply more grease and fine-tune the screws slightly.
5. Final tightening
- Tighten all screws securely without over-tightening to avoid deformation.
It is important to handle the hinges gently throughout the process. The hinges are robust but not heavy-duty tools.
Question: Do you work with pre-drilled holes on the cabinet sides? If yes, how precisely were these positioned? This greatly influences the difficulty of adjusting the doors.
narjon
13 Aug 2021 13:15
TEBILO schrieb:
Question: Do you work with pre-drilled holes on the cabinet sides? If so, how exactly are these aligned?
Thank you for the detailed instructions! In fact, my holes are pre-drilled and fairly precise, but there is a slight deviation of about 1-2 mm (0.04-0.08 inches) on one of the modules, which makes precise adjustment somewhat difficult. I suspect this is also the cause of a slight wobble in one door and occasional noises when closing.
Would you recommend modifying these holes afterwards, or is it better to compensate for the deviations by adjusting the hinges? Is there perhaps a technique to rework the holes without too much effort?
I’m looking forward to your opinions, as I want to achieve a flush and quiet result with minimal effort.
