ᐅ Cleaning Tips for Greasy Kitchen Cabinets (Ikea Metod)
Created on: 11 Feb 2020 08:37
Keken58
Keken58
11 Feb 2020 08:37
Hello everyone, I have been using the Ikea Metod cabinet fronts in my kitchen for some time now, which are known to be quite easy to maintain. However, with the white fronts, I am increasingly having issues with greasy stains, especially after cooking. I have tried various cleaning products, but either the grease removal is insufficient, or the surface starts to lose its gloss or looks dull after frequent cleaning.
I am therefore interested in which cleaning methods and products you specifically recommend for heavily greasy kitchen fronts of the Metod system. Which products are effective but still gentle on the surface? Are there any particular techniques that help to remove grease thoroughly without damaging the fronts? And are there any home remedies that deliver good results?
I look forward to your experiences and tips that are tailored to the typical plastic or melamine fronts of Ikea Metod. Thanks in advance for your feedback!
danial60
11 Feb 2020 12:16
Hello Keken58,
First of all, it is important to avoid aggressive or abrasive cleaners when cleaning Ikea Metod kitchen fronts – which are mostly made of melamine or plastic coating – as these can damage or dull the surface. For the greasy stains you described, I recommend a step-by-step approach:
- Start by wiping the surface with lukewarm water and a mild dishwashing detergent to remove most of the grease.
- Then, you can apply a small amount of rubbing alcohol or an alcohol-based glass cleaner locally, as these effectively break down grease without damaging the surface. Important: do not soak, just let it sit briefly.
- For stubborn grease, a mixture of warm water and a bit of baking soda can also be gently worked in with a soft sponge.
- After cleaning, it’s best to wipe again with a damp cloth and dry the surface to avoid streaks or residues.
I would also recommend using microfiber cloths for every cleaning, as they are gentle yet absorb dirt well.
One more question: Are your fronts smooth or matte? Sometimes the surface can react differently to cleaning agents.
This method should help you control the grease film effectively without damaging the surface.
LAYNE
11 Feb 2020 18:22
danial60 schrieb:
I would also recommend using microfiber cloths for every cleaning, as they are gentle yet effective at picking up dirt.
Absolutely, I agree with that! Especially on greasy surfaces, a good microfiber cloth often works wonders. I find it often works better than many cleaners.
I have a little extra tip: for stubborn grease, I mix a solution of warm water and a bit of dish soap with a few drops of lemon juice. It effectively removes grease and even leaves a fresher scent. Afterwards, wipe with clean water and dry.
But be careful not to use abrasive cleaners or scrubbing sponges since they can quickly cause small scratches on the surface. Unfortunately, these remain visible, and then you can easily end up with damage without much effort.
In general: many things work best with gentle mechanical cleaning and mild agents. And if the shine ever dulls, I’ve found that a special care oil for plastics (e.g. silicone-based treatment) can gently restore the gloss without damaging the surface.
Hope this helps!
Linavin
12 Feb 2020 09:05
Keken58 schrieb:
Which agents are effective yet gentle on the surface? Are there specific methods that help remove grease sustainably without damaging the fronts?
I think it’s important to critically consider how thorough the cleaning really needs to be and whether preventive measures might be more effective.
From my perspective, preventing grease buildup over time is more important than perfect cleaning. Simple habits like wiping immediately after cooking or placing a small bowl with degreaser nearby can help.
Also, many recommend alcohol, glass cleaner, or baking soda, but the effectiveness and especially the long-term compatibility with melamine fronts is not always clearly proven. It would be interesting to see if there are any long-term studies from Ikea or independent tests documenting their effects. I would definitely recommend a pH-neutral cleaner, as strong alkaline or acidic cleaners can damage the material.
Regarding home remedies:
- Vinegar is acidic and can damage surfaces
- Alcohol-based products might dry out the surface
Overall, I consider a combination of mild cleaning, prompt removal of grease traces, and maintenance to be the most sensible approach.
Does anyone know of reliable studies or experiences confirming the long-term use of, for example, alcohol on Metod fronts? I remain rather skeptical.
