ᐅ Neatly Installing Ikea Metod Baseboards and Adjusting for Uneven Floors
Created on: 1 Nov 2021 18:02
Nupe68I am currently facing the challenge of installing the baseboards from the Ikea Metod kitchen system neatly. Specifically, I am looking for the best way to adapt them to uneven floors without creating unsightly gaps or large spaces. The baseboards should fit as flush as possible and be mounted in an aesthetically pleasing way. Has anyone had experience with attaching and adjusting the Metod baseboards on floors with significant irregularities? What techniques or tools have you used to achieve a clean and durable solution? I would appreciate any advice on tools, installation steps, necessary preparation, or potential problem areas.
Basically, it is important to check the floor for unevenness with a spirit level before installing the baseboards and, if necessary, prepare the surface by sanding or leveling. For the Metod baseboards, Ikea recommends flexible installation, usually using clips that allow some height tolerance. In case of significant unevenness, it is advisable to align the baseboards with the lowest point of the floor and compensate for higher areas using small plastic wedges or foam strips. This prevents visible gaps and ensures the baseboards fit securely. Alternatively, a flexible acrylic sealant can be applied at the bottom to conceal minor gaps.
The topic may sound a bit dry at first, but installing baseboards on uneven floors is actually somewhat of an art! Personally, I have always tried to wedge the Metod skirting boards in place using small wooden shims. This has the advantage of preventing rattling while still keeping them looking perfectly straight. You need a bit of patience, but the fiddling is worth it – no gaps, and everything looks like a real piece of furniture. And if you do end up with a small gap, you can conceal it with color-matched filler or sealant. So don’t worry, it’s definitely doable!
At first, I was quite uncertain because my floor was really uneven. The corners were especially tricky. But what helped me was patiently adjusting smaller sections of the baseboard—cutting them to fit and placing them loosely at first, then using small spacers or felt pads to adjust the pressure. Sometimes it didn’t look perfect right away, but with some time, it works out. It’s also important not to get discouraged, especially if it’s your first time doing something like this. Check regularly that everything is still aligned properly and make adjustments if needed.
usbla schrieb:
In case of significant unevenness, it is recommended to align the baseboards to the lowest point of the floor and compensate for the higher areas using small plastic shims or strips of foam rubber. Thanks for the tip, that matches my thoughts as well. How thick can the shims be at most without causing the baseboards to tilt forward too much or become unstable? And is it better to place the shims only at specific points or distributed lengthwise at several spots? I ask because I want the solution to be as durable and “invisible” as possible without the baseboard loosening over time.
edisondan2 Nov 2021 08:48Regarding stability: wedges should be as flat as possible, with a maximum thickness of 5 mm (0.2 inches), as thicker wedges can reduce the clamping pressure on the fastening clips. Long, narrow strips made of foam rubber or plastic wedges are ideal because they distribute the load evenly and work under both compression and tension. It is also advantageous to fix the wedges in glued areas, for example with double-sided tape, to prevent slipping. Additionally, the mounting system of Metod baseboards is designed to accommodate minimally flexible material. Point-specific wedges, on the other hand, can cause pressure marks and deform the baseboard.
