ᐅ Neatly Installing Ikea Metod Baseboards and Adjusting for Uneven Floors
Created on: 1 Nov 2021 18:02
Nupe68
I am currently facing the challenge of installing the baseboards from the Ikea Metod kitchen system neatly. Specifically, I am looking for the best way to adapt them to uneven floors without creating unsightly gaps or large spaces. The baseboards should fit as flush as possible and be mounted in an aesthetically pleasing way. Has anyone had experience with attaching and adjusting the Metod baseboards on floors with significant irregularities? What techniques or tools have you used to achieve a clean and durable solution? I would appreciate any advice on tools, installation steps, necessary preparation, or potential problem areas.
Tinaneo
2 Nov 2021 09:34
Elodie schrieb:
Personally, I have always tried to wedge the Metod strips with small wooden shims, which has the advantage that they don’t rattle and still look perfectly straight.
I just wanted to add that wooden shims can swell when exposed to moisture in the room and, in the worst case, could warp the baseboard due to pressure if there is no ventilation. Therefore, rigid plastics or foam rubber, as already mentioned, are better options. Using wood is not incorrect, but one should consider the long-term effects. Also, I wonder if the simple clip clamping system might become problematic if the shims create too much thickness. Does anyone have long-term experience with this?
PEDRO40
2 Nov 2021 10:02
From personal experience, I can say that some improvisation is allowed when dealing with uneven floors. In my case, the floor was quite bumpy, so I used a bit of flexible silicone adhesive in certain spots to prevent any movement. This helped to secure and dampen the baseboard without requiring much additional work. I also find it important to measure carefully with a long spirit level and mark precisely so that the cutouts fit perfectly. This way, the final result looks quite professional, even if the floor is challenging.
meoreo
2 Nov 2021 11:24
Baseboards are best aligned at the lowest point when dealing with uneven surfaces. Distribute wedges or foam tape evenly along the length, not just in spots. Make sure clips snap in firmly; otherwise, the installation will be unstable. Don’t be too sparing when sealing the gap at the bottom—silicone works wonders. Done.
DUVIN
2 Nov 2021 11:58
Short and clear: Use plastic wedges or foam rubber and distribute them evenly. Make sure to mount on securely fitting clips. If it doesn’t close perfectly, seal with acrylic or silicone. This way, the baseboard stays clean and firmly installed.
