ᐅ IKEA Metod – 12 or 8 Legs for 3 Cabinets?
Created on: 15 May 2016 17:12
tobi77_8767
tobi77_8767
15 May 2016 17:12
Hello
I am planning a kitchen unit with 3 base cabinets (each 60cm (24 inches) wide). Usually, each cabinet stands on 4 Metod plastic legs (= 12 in total). According to the instructions, it is also possible to place the legs at the junction between two cabinets, which would reduce the total number of legs by 4.
Has anyone tried this before? Does this method work well in practice, and is it stable enough? Any disadvantages? More hassle? I assume assembly would then only be possible with two people?
Regards
Tobi
IKEA-Experte
16 May 2016 20:20
To what extent something can be done alone depends on one’s own skill.
So far, I have always placed my cabinets on their own legs, so that I can pull one out if necessary.
tobi77_8767
16 May 2016 21:31
..right, pull it out…. I hadn’t thought of that at all, especially since the high-voltage connection is hidden behind a cabinet. Well, I’ll just have to go back to Ikea and buy another set of legs.
IKEA-Experte
17 May 2016 09:53
Nevertheless, you should cut out the back panel at the point where the electrical connection is located.
Strahlemann-69
19 May 2016 20:40
I have a pair of legs where BOTH cabinets stand, with a 3cm (1.2 inch) stone countertop from the stonemason on top, weighing 120kg/sqm (25 lbs/sqft). It holds perfectly.
I built the entire "U" like this. With about 125kg (275 lbs) per leg, my kitchen supports a total weight of 3 tons (6,600 lbs), and the stone weighs around 800kg (1,760 lbs). I don’t have that many groceries or pots inside anyway. It holds!!!
Agnus
22 Mar 2018 18:04
I have a question related to this. I want to use a Metod tall cabinet as a shelf without doors. Can I simply leave out the legs, or is it better to have legs for the structural stability of the tall cabinet?
