ᐅ IKEA Malm Nightstand Plastic Feet Damaged – Where to Find Replacements?
Created on: 1 Feb 2019 08:37
dunipu
I have a problem with my IKEA Malm bedside table. The plastic feet that support the piece of furniture have worn out after several years of heavy use. They are either completely worn down or even broken, causing the table to be unstable. My question is: where can I find suitable replacement parts for the plastic feet of the IKEA Malm bedside table? I would prefer not to replace the entire table but just the feet.
Has anyone had experience with replacing these plastic feet? Would it be possible to use similar feet from a hardware store, or are the dimensions so specific that only original replacement parts will fit? If anyone knows a source or has tips for DIY replacement, I would be very grateful. Thanks in advance!
miAlessio
2 Feb 2019 11:30
I would like to add why original matching feet sometimes have advantages:
IKEA models are often designed for these specific parts, so using incompatible alternatives can cause slight height differences or varying contact surfaces, which may lead to wobbling.
Therefore:
- It is best to measure precisely.
- Check if the screw holes and fixing method are identical.
- If you choose alternatives, consider using washers or thin felt pads to adjust the height accurately.
This way, you get an almost exact replacement and avoid wobbling later on.
theo63
2 Feb 2019 15:14
I would like to add another perspective that is sometimes overlooked:
Why do the original feet wear out so quickly? Often, the issue lies with the material – cheap plastic tends to degrade faster. My suggestion would be to switch directly to more durable materials, for example, metal feet with plastic or rubber pads.
This has the advantage of significantly increasing the lifespan, even if the price is slightly higher. This way, the overall durability of the bedside table can be extended – sustainability included.
Of course, this is a deviation from the original, but for a bedside table that relies on stability, it can offer real added value.
Johnathon
3 Feb 2019 09:03
Good morning,
In terms of sustainability, I completely agree with theo63. It is worthwhile to prioritize material quality when replacing parts.
Additionally, you might consider simply removing the plastic feet and installing a different type of adjustable feet yourself, for example, height-adjustable metal furniture feet. This is especially helpful if the floor is not perfectly even, as it better compensates for unevenness.
As an example: 4 screw-in feet with rubber pads can be found from around 5 euros in hardware stores or online. You may need to pre-drill holes, but that is quite manageable.
How are you dealing with the screw holes? Are they still in good condition, or is the fixture already a bit loose, dunipu?
dunipu
3 Feb 2019 09:45
Johnathon schrieb:
How are you dealing with the screw holes? Are they still in good condition, or is the fixture already a bit loose?
Fortunately, the screw holes are still intact. The nightstand only wobbles because of the plastic part that broke. So I can safely use new screws without compromising stability.
I’ll probably call IKEA customer service first, and if that doesn’t work out, I’ll try alternative furniture glides from the hardware store that are more robust. Thanks again for all the tips!
