ᐅ IKEA Malm Nightstand Plastic Feet Damaged – Where to Find Replacements?
Created on: 1 Feb 2019 08:37
dunipu
I have a problem with my IKEA Malm bedside table. The plastic feet that support the piece of furniture have worn out after several years of heavy use. They are either completely worn down or even broken, causing the table to be unstable. My question is: where can I find suitable replacement parts for the plastic feet of the IKEA Malm bedside table? I would prefer not to replace the entire table but just the feet.
Has anyone had experience with replacing these plastic feet? Would it be possible to use similar feet from a hardware store, or are the dimensions so specific that only original replacement parts will fit? If anyone knows a source or has tips for DIY replacement, I would be very grateful. Thanks in advance!
keogla
1 Feb 2019 14:29
I replaced the plastic feet of my Malm furniture with screw-on glides from the hardware store. They fit well, don’t look original, but are sturdy and work properly.
Johnathon
1 Feb 2019 15:52
theo63 schrieb:
In my experience, IKEA does promise that spare parts are available, but in practice, it is often complicated
I can confirm that. I personally searched for spare parts for a MALM desk, and the delivery times were sometimes several weeks, with some small parts not available at all.
Therefore, my addition: If it is particularly urgent, you can also contact IKEA returns or check online marketplaces like eBay Classifieds. Sometimes people sell used but intact legs from broken nightstands. But be careful—check for proper fit and condition.
miAlessio schrieb:
I recommend plastic gliders with screw fittings that have similar dimensions
It is important that the gliders have a flat, load-bearing surface. Cheap gliders with feet that are too small quickly become unstable on heavier furniture.
Colby42
1 Feb 2019 17:18
It’s great to see you all discussing this topic so thoroughly! 🙂
I once had a Malm bedside table too, and after a while, the legs started wobbling so much that I had to get new ones as well. I simply called IKEA, and since the product was still relatively new, they sent me replacement legs free of charge. So it’s worth politely asking – sometimes you can get more help than you expect!
Good luck to everyone with the repair, it really helps to keep the furniture lasting much longer!! :-)
CHARLES69
1 Feb 2019 18:21
I agree with Colby42! I had the same issue a few months ago. I simply called IKEA customer service, explained the problem politely, and they sent me replacement feet without any hassle.
Sometimes it really pays off to be patient and friendly. Good luck with the repair and enjoy your like-new nightstand! 🙂
dunipu
2 Feb 2019 08:10
Thank you very much in advance for the numerous helpful answers!
I measured the dimensions earlier: The plastic part is cylindrical, with a diameter of about 23 mm (0.9 inches) and a height of just over 12 mm (0.5 inches). The feet are attached to the wood with a small screw. I assume these are the usual furniture glides, but specifically for the Malm bedside table.
I will call IKEA today to ask about replacements. If that doesn’t work out, I will take the measurements with me to the hardware store and look for suitable screw-on glides.
A question to the experienced users here: How good are these alternative furniture glides in terms of durability and whether the bedside table remains stable? Are they comparable to the original IKEA plastic version?
Dwight49
2 Feb 2019 10:42
dunipu schrieb:
How durable are these alternative furniture glides, and will the bedside table remain stable?
In my experience, screw-in glides made of sturdy plastic or rubber often have better durability than thin IKEA plastic feet. They also help absorb floor vibrations and protect the flooring.
It is important that the screw is firmly secured and the glide fits precisely. A loose connection directly affects the stability of the table.
I recommend choosing a glide with a wide contact area and sufficient load capacity. This information is usually available in the product details.
