ᐅ IKEA BESTA – How Can I Refinish the Surface Myself?
Created on: 26 Jan 2021 08:17
Anjulianna
Anjulianna
26 Jan 2021 08:17
I am planning to repaint my IKEA Besta furniture series myself but have little experience with painting over coated furniture surfaces. My main question is: How do I properly prepare the surface to ensure good adhesion and long-lasting results? Specifically, I am interested in which abrasives and grit levels are best suited, whether a primer is necessary, and which type of paint is recommended for a durable and even finish. It would also be helpful if someone could share advice on the recommended workflow, including drying times between coats, so I can start the project with as few mistakes as possible.
Parbo
26 Jan 2021 14:53
Anjulianna schrieb:
How do I properly prepare the surface so that the paint adheres well and is durable?
Very good, well-phrased question. The key to painting a coated surface like IKEA BESTA is thorough preparation:
- First, you should lightly sand the surface with fine-grit sandpaper, I recommend grit 280 to 320. The goal is to dull the glossy foil or coating so the new paint layer will properly adhere. Be careful to sand gently to avoid breaking through the thin layer.
- After sanding, remove all dust thoroughly, preferably with a damp, lint-free cloth.
- Priming is highly recommended depending on the paint used. It is best to use a bonding primer (also called adhesion primer) designed specifically for smooth plastic or melamine surfaces.
- For the paint itself, opt for high-quality water-based acrylic paints. Drying times vary, but generally it’s advisable to wait at least 6 to 8 hours between coats and to perform intermediate sanding with very fine sandpaper (400 to 600 grit) to achieve a smooth, even finish.
- Finally, allow sufficient curing time—it can sometimes take several days to reach optimal durability.
Do you already have a specific product in mind, or would you like tips on the best tools and painting environment as well?
bulanau
27 Jan 2021 10:36
Parbo schrieb:
Priming is highly recommended depending on the paint used. It’s best to use an adhesion primer specifically designed for smooth plastic or melamine surfaces.
In addition, I suggest the following step-by-step guide:
- Cleaning: First, thoroughly clean the BESTA surface with a degreasing cleaner. Dust and grease prevent proper adhesion.
- Sanding: As Parbo already mentioned, lightly sand with 280–320 grit sandpaper, and if needed, remove dust again after the first sanding.
- Priming: Use an adhesion primer specifically formulated for coatings or laminates. The primer must be fully dry, which can take 12 hours or more.
- Intercoat sanding: After priming, lightly sand the surface with 400 grit sandpaper, especially to smooth out minor imperfections.
- Paint application: Spray paint is preferred for even coverage, alternatively use high-quality foam rollers for smooth application.
- Coats: Apply at least two coats of paint. Between coats, lightly sand again and remove dust.
Common mistakes I often see are insufficient dust removal after sanding or skipping the adhesion primer. These should be avoided to prevent paint peeling later on.
AUSTINREN
28 Jan 2021 09:05
Brief and to the point: For IKEA BESTA surfaces, I recommend a special adhesion primer designed for laminated furniture, available in spray form. Important points are:
- The surface must be free of dust and grease.
- Sand with 280 grit, then thoroughly remove all dust.
- Apply the primer in thin layers and allow to dry well (at least 12 hours).
- Then apply two thin coats of spray lacquer, preferably polyurethane-based, for high abrasion resistance.
- Lightly sand between coats with 400 grit sandpaper.
Using standard acrylic paints without an adhesion primer will hardly give you satisfactory durability on smooth laminate surfaces.
Danial
28 Jan 2021 16:22
bulanau schrieb:
Typical mistakes I often see are insufficient dust removal after sanding or missing primer application.
I agree, but I would add the question of whether the effort and choice of the paint system really make sense for a DIY painter. Especially with IKEA BESTA, the surface usually consists of melamine resin-coated panels – in this case, the paint can easily chip off if the substrate is not perfectly prepared.
My suggestion is always to start with a small test area and check the adhesion over several days/cycles (moisture, use).
It would also be interesting to know what kind of final finish is desired – matte, high gloss, or something in between? Depending on the requirements, a spray finish or coating with special 2-component (2K) systems might be worthwhile.
However, I would also like to raise the question of whether an alternative surface treatment (e.g., replacing the foil yourself or applying furniture foil) could be more practical or economical from a technical and financial perspective.
