ᐅ IKEA BESTA – How can I make this furniture piece winter-proof?
Created on: 4 May 2022 08:23
Saune46
Saune46
4 May 2022 08:23
I have an IKEA BESTÅ piece of furniture that I use in my semi-detached carport. Since it gets significantly colder and more humid there during winter compared to indoors, I am looking for ways to winterize it without completely dismantling it or risking damage to the material. I am particularly interested in how to best protect the wood surfaces, whether special impregnations or sealants are advisable, and how to prevent moisture damage caused by condensation or frost. Are there also practical tips on how to optimally preserve the furniture against prolonged exposure to moisture and temperature fluctuations? I look forward to your experiences and recommendations.
Nofege
4 May 2022 10:41
Basically, the IKEA BESTÅ is usually made from a combination of engineered wood panels with a foil coating. If the furniture is placed in a carport, I recommend the following steps to make it winterproof:
- Cleaning: First, thoroughly clean the surface to ensure no dirt residues interfere with the protective measures.
- Protective finish: You can apply a clear, water-repellent sealant specifically designed for furniture. Make sure it remains effective even at colder temperatures.
- Silicone joints: If edges are exposed, sealing them with transparent silicone can help prevent moisture from entering.
- Floor base: To avoid rising moisture from the ground, place the BESTÅ on slightly raised feet or a wooden batten.
- Covering: Additionally, a water-resistant tarp or tarpaulin helps protect the furniture against direct rain and snow.
Common mistakes include neglecting edge sealing or placing the furniture directly on cold concrete, which can cause moisture damage. The furniture is not designed for permanent outdoor use, but with these measures, you can effectively protect it against winter conditions.
KARJU
5 May 2022 14:07
Nofege schrieb:
If edges are exposed, sealing them with clear silicone can prevent moisture from entering.
Sealing the cut edges is essential because they are particularly susceptible to water absorption. Additionally, I recommend applying a special furniture impregnation based on acrylic resin, which makes the material breathable but water-repellent. It is also important to ensure a stable support underneath to prevent water pooling and to allow air circulation beneath the furniture.
Over time, you should check whether the foil coating remains intact, as cracks allow moisture to penetrate, causing the boards to swell. Therefore, regular inspections every few weeks during the winter are advisable.
reece70
6 May 2022 09:52
I would recommend placing the furniture on legs, sealing the edges with silicone, and using a water-repellent varnish. Then store it under a tarp. This way, you can protect the BESTÅ well against frost and moisture.
BOSULE
7 May 2022 18:15
Saune46 schrieb:
Are there any practical tips on how to best protect the furniture from prolonged exposure to moisture and temperature fluctuations?
I completely agree with that. For furniture like the BESTÅ, which is not designed for outdoor use, it is important not only to repel moisture from the surface but also to ensure proper ventilation. Trapped moisture and lack of air circulation can quickly lead to mold and damage to the material.
My tip: Do not place the BESTÅ directly against a wall; leave about 5 cm (2 inches) of space to allow for air circulation. Additionally, if the back panel is accessible, you can add small ventilation holes inside without compromising stability.
The best way to make the furniture weather-resistant for winter is a combination of good edge sealing, protective coatings, and sufficient ventilation.
