I am currently planning to use my Ikea Besta furniture as a base for a worktop in my home office. I have a question: How can I build a stable and durable work surface on top of the Ikea BESTA units? Specifically, I am interested in aspects such as how to attach the worktop, recommendations for materials (for example, wood, MDF, stone-effect surfaces), and what to consider when cutting to achieve a clean, load-bearing result. It would also be helpful to know if certain accessories from Ikea or third-party suppliers are recommended to securely connect the worktop to the BESTA units.
I would greatly appreciate useful tips, personal experiences, and possibly step-by-step instructions to avoid common mistakes from the start.
AUSTINREN23 Feb 2021 11:23In general, I recommend the following when installing a countertop on Ikea BESTA units:
- Use sturdy materials such as 18-22 mm (0.7-0.9 inches) thick plywood or carpenter-grade board for high load capacity.
- The countertop should be cut precisely to the dimensions of the BESTA base cabinets; a jig or template can be helpful for accuracy.
- Attachment: Screw from underneath through the cabinet frame into the countertop, always pre-drill to prevent splitting.
- Alternatively, some third-party suppliers offer special adapters that allow a millimeter-precise connection, but the standard method with screws is usually sufficient.
It is important to align the cabinet frames accurately and protect the material from moisture, especially with wooden boards. Good sealing or varnishing significantly increases durability.
I mounted a countertop made of MDF on my BESTA units myself. It is important that you:
- choose a moisture-resistant MDF board
- lightly sand the board with fine sandpaper before painting
- use high-quality mounting brackets to further stabilize the board
Additionally, I recommend leaving a small overhang edge; this improves the look and protects the edges of the supporting structure.
A small guide that can help with assembly:
1. Preparation:
- Determine the exact dimensions of the BESTA units so the panel fits perfectly.
- Choose your material (e.g., plywood, MDF, chipboard) according to the intended use and stress requirements.
2. Cutting:
- Recommended panel thickness: 18–22 mm (0.7–0.9 inches).
- Pre-smooth edges with a rounding router bit or sandpaper to avoid splintering.
3. Attachment:
- Screw from underneath through the BESTA carcasses into the panel.
- Remember to pre-drill to protect the material.
- Alternatively, use mounting brackets for better stability.
4. Finishing:
- Seal the panel well with varnish, oil, or laminate, especially in damp rooms.
- Apply edge protection or edge banding to protect the edges.
Common mistakes:
- Not sealing the edges – this quickly causes swelling, especially with MDF.
- Incorrect measurements – the panel will not fit accurately.
Feel free to ask if you have questions about any of the steps!
1. Preparation:
2. Cutting:
3. Attachment:
4. Finishing:
Common mistakes:
Israel62 schrieb:
Screw the countertop firmly, preferably from underneath into the BESTA carcasses.Sure, that’s the classic method. However, I would argue that just screwing it in place isn’t always enough. Especially if the countertop is heavy or particularly long, it’s worth considering additional supports or reinforcements.
Also, I think many people underestimate how easily simple screws can loosen over time during daily use. Metal brackets or even special glue joints can help as secondary safety measures.
So, if you want to be on the safe side, don’t rely on screws alone. Quality needs to be demanded here— the IKEA approach of “Just put it on and done” isn’t always the best solution.
